DropBox and LinuxCNC;
8 years 4 weeks ago #118421 by C_M_H
DropBox and LinuxCNC; was created by C_M_H
Is anyone using Dropbox on their LinuxCNC machine?
I ask because I've recently gotten a notice that DropBox may longer work on my debian 7.11, ext4 file system. The notice gives links to Ubuntu and Fedora, but I don't see any info regarding Debian. Even if I did I suspect it would break my setup.
Will this affect anyone else? Does anyone have any work arounds?
DropBox has been great for me, as I was never able to reliably get my WIn PC, Mac, and Linux box to play nice on my local network.
Thanks,
Craig
8 years 4 weeks ago #118425 by tommylight
Replied by tommylight on topic DropBox and LinuxCNC;
Personally i do not use dropbox at all, i never did like it, way to invasive. I like my stuff to remain my stuff.
Also have a lot of public IP, so i set my own servers for whatever i may need them.
The following user(s) said Thank You: racedirector
8 years 4 weeks ago #118437 by rodw
Replied by rodw on topic DropBox and LinuxCNC;
I must confess I'm on Tommy's side. Google Drive is a much better solution becasue you can edit office documents directly. I've got a Synology NAS on my network which syncs to Google drive and it also has a Dropbox cloud sync tool. This is much more efficient as you only have one copy of your drop box files for all PC's on your network sitting on your NAS. connecting to the NAS is simple on Windows and Linux, and I'm sure it is for mac as well.
8 years 2 weeks ago #118884 by Mike29
Replied by Mike29 on topic DropBox and LinuxCNC;
Any update on resolving this as I'm now disconnected from my dropbox folder on my linuxcnc machine. Any help is appreciated without changing to Google drive.
Thank you
8 years 1 week ago #119085 by kiaw
Replied by kiaw on topic DropBox and LinuxCNC;
I am in the same boat. Dropbox works great for me between home and work. I've also used the linux dropbox folder on my home network to keep using dropbox on my old xp machine, so I want to get dropbox running again.
In the short term, I go to dropbox on the web and upload and download files. For a "permanent" solution , I'm going to upgrade to debian stretch. The live iso of linuxcnc works all right and supports the dropbox desktop application. My main issue with the new iso is that it has only Preempt RT, not RTAI. Currently I use RTAI and have latency under 5000, so software step generation is faster than my small mill. Latency for the Preempt RT is up around 20,000, so I'll probably be adding a parallel card, maybe the 5125? to work with my Gecko 540.
  • AnnoyingMutt
  • New Member
  • New Member
8 years 1 week ago #119093 by AnnoyingMutt
Replied by AnnoyingMutt on topic DropBox and LinuxCNC;
The Ubuntu version listed on the dropbox website appears to be the same version as here mentioned here:
forum.linuxcnc.org/38-general-linuxcnc-q...ws-7?start=40#111206
To be honest I haven't used dropbox since then, but at the time it was working when I did the install.
Time to create page: 0.361 seconds
