Hello,
i have bought the above Touchscreen and i try to use it under LinuxCNC with gmoccapy... but of course, it did not run under Linux...
I start with a fresh linuxcnc-2.7-wheezy.iso installation.
than install USB utilities.
mill@CNCMill:~$ lsusb
Bus 001 Device 005: ID 148f:2573 Ralink Technology, Corp. RT2501/RT2573 Wireless Adapter
Bus 003 Device 002: ID 04f3:249f Elan Microelectronics Corp.
Bus 004 Device 002: ID 413c:2003 Dell Computer Corp. Keyboard
Bus 004 Device 004: ID 1c4f:0003 SiGma Micro HID controller
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
mill@CNCMill:~$
OK Display is found there with Elan Microelectronics. I have checked it with disconnecting the Display
Ok then check the X11 Support
nothing..
mill@CNCMill:~$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SIGMACHIP Usb Mouse id=9 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Power Button id=7 [slave keyboard (3)]
↳ Dell Dell USB Keyboard id=8 [slave keyboard (3)]
↳ ACPI Virtual Keyboard Device id=10 [slave keyboard (3)]
mill@CNCMill:~$
I have googled a lot but have not find a solution
