Ethercat Latancy
- thefabricator03
- Visitor
14 Jul 2019 13:05 #139308
by thefabricator03
Ethercat Latancy was created by thefabricator03
Hi Guys,
Not sure where to post this,
When using Linuxcnc as a ethercat master, Does latency of the hardware it is running on become a factor?
I know with say ethernet breakout board you can get away with a bit of latency due to step generation being done on the board rather than through the software,
But since Ethercat is processed through the software is it dependent on the Latency of the hardware or because it is only sending out packets of data for the slave devices to read latency is not a issue?
- Thank you received: 7488
14 Jul 2019 13:45 #139309
Replied by tommylight on topic Ethercat Latancy
It should be similar to mesa ethernet, meaning there is a motion controller that commands the rest of the devices. At least that should be how Bockhoff does it, if i remember correctly, been over 4 years since i read about it.
Grotius and some other members here have much more experience with them, so might want to wait for them to reply.
I am not the one to give any advice on that subject, nor will i be for the forseable future !
- thefabricator03
- Visitor
14 Jul 2019 13:48 #139310
by thefabricator03
Replied by thefabricator03 on topic Ethercat Latancy
Thanks Tom,
My understanding is that the Linuxcnc system is that motion controller or ethercat master, I hope someone can clear that up for me.
- Thank you received: 5330
14 Jul 2019 13:52 - 14 Jul 2019 13:53 #139311
Replied by PCW on topic Ethercat Latancy
LinuxCNC requires real time (low predictable latency) and ability to meet the thread
invocation rate for the servo and possibly base threads. This requirement is
independent of the type of external hardware. Smart external hardware typically only
uses the (slower) servo thread so its easier to meet the latency requirement than simple hardware
(GPIO or parallel port) that requires a base thread to generate steps/read encoders etc etc.
Last edit: 14 Jul 2019 13:53 by PCW.
The following user(s) said Thank You: tommylight, thefabricator03
- jirkam
- Thank you received: 9
31 Dec 2019 10:37 #153598
by jirkam
Replied by jirkam on topic Ethercat Latancy
Good day.
And what is the recommended maximum value for the latency test? To make the servo drive work properly?
My lineup:
MB: H81M-P33
drivers: ASD-A2-0721-E
The latency test shows around 18,000 ns for the servo thread. Is it high value?
Thank you for answer.
My lineup:
MB: H81M-P33
31 Dec 2019 12:16 #153600
That is good latency.
- jirkam
31 Dec 2019 13:24 #153602
by jirkam
Thank you for your response.
So do you think the EtherCAT servo won't hiccup?
I tried it on ASRock A320M-HDV R3.0 and there was a problem (drives hiccupseed).
But on ASRock A320M-HDV R3.0 the latency was 40,000 ns.
That's why I'm afraid.
Thank you very much.
- Grotius
- Thank you received: 2349
31 Dec 2019 15:13 #153605
by Grotius
Replied by Grotius on topic Ethercat Latancy
For Ethercat latency,
There is a difference between using servo's (pid) or steppers (pulse).
When using steppers, you can use a ethercat stepdrive 50v 5amp. I don't recommend the usage of the bechhoff stepdrive's because of cost's and power. Usage of chinese drives 80v 8amp's give more power if needed, cost's are less.
This will result the step pulse generation is done by linuxcnc. If you compare the parport output with a ethercat output. The parport
can move your machine for example max : 12000mm/min, the ethercat will do it max : 20000mm/min.
Setting up the ethercat steppers can be quite difficult, but i have examples that will work quite good.
For servo's, the servo drive will only go to a position. The drive get's PID (destination info from linuxcnc) and will go there..
- jirkam
31 Dec 2019 18:23 - 31 Dec 2019 21:47 #153630
by jirkam
I will use servo's (pid). Delta driver ASDA A2-E and 750W Delta servo motor ECMA-CA0807RS with absolute encoder.
Is it difficult to switch servo to position control?
Sorry to ask stupid questions.
It is a pity that this list is not updated.
wiki.linuxcnc.org/cgi-bin/wiki.pl?FixingSMIIssues
Or do you know about a more current list of chipsets?
Very thanks
Very thanks
Last edit: 31 Dec 2019 21:47 by jirkam.
- Grotius
02 Jan 2020 22:20 #153828
by Grotius
If you use delta servo's you can find existing examples on the net with google. I have seen them in the past.
I never used servo's on ethercat, but you can put the ethercat cable into the servo drive if the drive is ehtercat compatible.
An other way is to use the step-dir signal on the servo drive if available. (works good, but ethercat straight into the servo drive is nicer).
If you use pid, you don't have to worry about latency. Use the hybrid debian with linuxcnc, you can download it at this site.
Debian is basic, but very stable, with nice performance.
