Celerron N2807 or J1900
30 Jul 2019 08:32 #140941 by Clive S
Celerron N2807 or J1900 was created by Clive S
I am considering a Brix pc to run small plasma machine . Which of these two are more suitable Celerron N2807 or the J1900 ?
30 Jul 2019 09:12 - 30 Jul 2019 09:14 #140942 by rodw
Replied by rodw on topic Celerron N2807 or J1900
Clive, I would go with the J1900 as thats the Brix I have had on my table with a 7i76e. You need to use a USB wifi adapter on these machines and toss the included card out.
When I looked for you, the N2807 was 57% more energy efficient which rang warning bells for me re latency. But really I have no idea.
www.cpu-world.com/Compare/60/Intel_Celer...e_Celeron_N2807.html
EDIT and the Brix N3160 also works
Last edit: 30 Jul 2019 09:14 by rodw.
30 Jul 2019 16:07 #140955 by Clive S
Replied by Clive S on topic Celerron N2807 or J1900
Rod
There is only 2 usb's on these if you have to put a wifi dongle in how do you connect the wired keyboard and mouse?
  • Moderator
  • Moderator
30 Jul 2019 16:14 #140956 by tommylight
Replied by tommylight on topic Celerron N2807 or J1900
USB hub, preferably powered.
30 Jul 2019 16:19 #140959 by Clive S
Yes but not really a lover of these.
  • Moderator
  • Moderator
30 Jul 2019 16:40 #140960 by tommylight
Same here, usable for keyboard and mouse, maybe for WiFi, but there it ends. To slow for anything else.
31 Jul 2019 02:25 #140981 by rodw
Clive, My J1900 has 2 USB2 and 1 USB3.
So the USB3 goes to the monitor for touchscreen and it has a built in 3 port hub.
I use a Wireless Keyboard and Mouse Combo so it uses one USB2 leaving one for the Wifi Dongle. Its kinda handy having wireless as you can move the keyboard and mouse right out of the road..
The N3160 has an extra USB port from memory..
31 Jul 2019 06:41 #140986 by Clive S
Thanks Rod but the trouble is that there are variations like this one www.gigabyte.com/uk/Mini-PcBarebone/GB-BACE-3160-rev-10/sp#sp
but this is a j3160
edit: but I have now found this www.scan.co.uk/products/gigabyte-brix-bx...7xEUFUBoCHZwQAvD_BwE
Which has 3 usb :)
31 Jul 2019 07:12 - 31 Jul 2019 07:17 #140987 by rodw
Clive, pretty sure this is the N3160 unit I have www.gigabyte.com/uk/Mini-PcBarebone/GB-BACE-3160-rev-10#ov
I actually bought it and got it going then found a cheap J1900 in the same form factor which is the one I am using on the spaceship despite it having 1 less USB.
The wireless keyboard and mouse sets I use are only cheap about $20 or so. Had a key sticking a couple of days ago but removed it and cleaned it out and its fine again.
EDIT: That J1900 seems to be the one I have.
Last edit: 31 Jul 2019 07:17 by rodw.
31 Jul 2019 07:26 - 31 Jul 2019 07:26 #140988 by Clive S
Yes I have it ordered and it will be here tomorrow :)
Last edit: 31 Jul 2019 07:26 by Clive S.
