Compiling rt prempt kernel breaks kernel module rtl8192eu SOLVED!
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Mar 2020 20:37 - 13 Mar 2020 01:26 #159926 by bevins
Hi, I just got finished installing prempt kernel and the USB wifi module is now broke. It was working before. Does this have to do with not having the proper files when compiling?
Last edit: 13 Mar 2020 01:26 by bevins.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
12 Mar 2020 20:48 #159928 by BeagleBrainz
What distro are you using ?
What kernel did you install, did you install the headers, did you compile the kernel yourself ?
Do you have dmks installed, if you are using a debian/ubuntu distro ?
Did you recompile the module after booting into the new kernel ?
What version of gcc do you have ?
When you try to load the module are there any messages in dmesg ?
  • bevins
  • Platinum Member
  • Platinum Member
12 Mar 2020 22:47 - 12 Mar 2020 22:51 #159950 by bevins
Linux Mint 18.3 Mate
I compiled it from this. mirrors.edge.kernel.org/pub/linux/kernel.../linux-4.19.1.tar.xz and patched it with
this: mirrors.edge.kernel.org/pub/linux/kernel...-4.19.1-rt3.patch.gz
I assume the headers got installed from these files.
No
I did recompile the module after booting into the new kernel. I did not however unload the old module, I assume it would write over it. Not sure if this is true or not.
gcc version 5.4.0
I am getting this over and over.
[ 7310.838297] IPv6: ADDRCONF(NETDEV_UP): wlx503eaa005cdd: link is not ready
[ 7312.007452] wlx503eaa005cdd: authenticate with 74:da:88:7d:5d:b7
[ 7312.030864] wlx503eaa005cdd: send auth to 74:da:88:7d:5d:b7 (try 1/3)
[ 7312.234680] wlx503eaa005cdd: send auth to 74:da:88:7d:5d:b7 (try 2/3)
[ 7312.438700] wlx503eaa005cdd: send auth to 74:da:88:7d:5d:b7 (try 3/3)
[ 7312.642681] wlx503eaa005cdd: authentication with 74:da:88:7d:5d:b7 timed out
[ 7323.835252] wlx503eaa005cdd: authenticate with 74:da:88:7d:5d:b7
[ 7323.857616] wlx503eaa005cdd: send auth to 74:da:88:7d:5d:b7 (try 1/3)
[ 7324.058453] wlx503eaa005cdd: send auth to 74:da:88:7d:5d:b7 (try 2/3)
[ 7324.262449] wlx503eaa005cdd: send auth to 74:da:88:7d:5d:b7 (try 3/3)
[ 7324.466435] wlx503eaa005cdd: authentication with 74:da:88:7d:5d:b7 timed out
I forgot to add that it worked before compiling preempt kernel.
Output of ip a:
3: wlx503eaa005cdd: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
    link/ether 50:3e:aa:00:5c:dd brd ff:ff:ff:ff:ff:ff
Last edit: 12 Mar 2020 22:51 by bevins.
  • BeagleBrainz
  • Visitor
  • Visitor
12 Mar 2020 23:22 #159955 by BeagleBrainz
Ok no probs.
Go to this link
github.com/clnhub/rtl8192eu-linux
Clone the repo as you would for linuxcnc eg
git clone https://github.com/clnhub/rtl8192eu-linux.git
And follow the instructions, except for the bit about installing the headers.
Hopefully this should get you sorted.
One tip when recompiling a kernel, for furture reference, if you run
make deb-pkg
instead of anything else,
it will build deb packages that you can install using your preferred method: eg dpkg or gdebi
The ones you will want with this method are linux-image-xxxx.deb & linux-headers-xxxx.deb
You can also keep them for the future.
12 Mar 2020 23:22 #159956 by andypugh
At the command line, try the following
sudo systemctl enable wpa_supplicant.service
sudo wpa_supplicant -c /etc/wpa_supplicant.conf -i wlx503eaa005cdd &
sudo dhclient wlx503eaa005cdd
That is what I need to use to get my Wifi dongle to connect. (I have tried to make it automatic a couple if times). It is probable that the problem isn't the same, but the terminal output might contain clues.
The following user(s) said Thank You: bevins
  • bevins
  • Platinum Member
  • Platinum Member
12 Mar 2020 23:23 #159957 by bevins
I do not have linux-headers for 4.19.1-rt3, nor can I find them on the net.
12 Mar 2020 23:27 #159959 by phillc54
I had a similar issue recently that was resolved like this:
forums.linuxmint.com/viewtopic.php?p=1703637#p1703637
12 Mar 2020 23:32 #159961 by andypugh
If you compiled the kernel yourself, then "sudo make headers_install" in the kernel source directory might work.
  • bevins
  • Platinum Member
  • Platinum Member
13 Mar 2020 00:52 #159970 by bevins
Yeah, that just fixed the name for me to wlan
  • bevins
  • Platinum Member
  • Platinum Member
13 Mar 2020 01:00 #159973 by bevins
Yeah, just did that and it installed the headers. I am recompiling the driver and see what it does. It seems to be taking longer.
