Compiling rt prempt kernel breaks kernel module rtl8192eu SOLVED!
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Mar 2020 01:25 #159976 by bevins
Ok no probs.
Go to this link
github.com/clnhub/rtl8192eu-linux
Clone the repo as you would for linuxcnc eg
git clone https://github.com/clnhub/rtl8192eu-linux.git
And follow the instructions, except for the bit about installing the headers.
Hopefully this should get you sorted.
One tip when recompiling a kernel, for furture reference, if you run
make deb-pkg
instead of anything else,
it will build deb packages that you can install using your preferred method: eg dpkg or gdebi
The ones you will want with this method are linux-image-xxxx.deb & linux-headers-xxxx.deb
You can also keep them for the future.
Thank you, that did the trick.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
13 Mar 2020 02:12 #159978 by BeagleBrainz
Cool
Yeah it takes forever to build the kernel that way and uses up a lot of disk space, but after the build you can basically delete the source directory.
Just keeps the debs and your good to go.
With the dkms if you do build and install a new kernel it should rebuild the kernel module to suit, no need to interfere.
Time to create page: 0.094 seconds
