Embedded LinuxCNC distro possible?
  • spma
  • spma's Avatar Topic Author
  • Junior Member
  • Junior Member
21 Mar 2020 17:05 #160998 by spma
Hi everyone,
This is going to be a, somewhat, very technical Linux question, so bare with me for a bit...
I've been tinkering with some embedded Linux experiments using musl-libc , Busybox , Toybox , etc., building a few embedded Linux systems from scratch (I've done a couple of Linux From Scratch builds, which help a lot to understand the concepts).
I started thinking "Why not try and build an 'embedded LinuxCNC' distro??".
So the idea is to try and create the most compact Linux system possible, aimed at only running LinuxCNC.
I know all about needing to satisfy dependencies and all, but there is one question:
Does anyone know if LinuxCNC depends (either directly or not) on glibc to work?
I this would help fighting the problems LinuxCNC is facing about future-proofness as well as boosting performance in RPI control based systems.
I'm hoping to have some feedback about this, I want to know if this is something that could be worth putting time into.
Miscelaneous:
There is an unmaintained, undated comparison between C/POSIX standard library implementations in Linux that shows how musl-libc compares with other libraries, actually beating glibc in some points.
My best regards,
Simão A.
21 Mar 2020 17:48 #161009 by Bari
Replied by Bari on topic Embedded LinuxCNC distro possible?
We have been using Gentoo with LCNC for quite a while. So you can do this but you will very likely be on your own for support. People involved in the main project are already pretty busy.
There is already a Gentoo 64b image for the Rpi4 that makes it easy to update if you are not used to emerge.
github.com/sakaki-/gentoo-on-rpi-64bit
I'd look at this for a starting point to build something stripped down and stable for the Rpi4.
The following user(s) said Thank You: spma
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
21 Mar 2020 17:51 #161010 by BeagleBrainz
Replied by BeagleBrainz on topic Embedded LinuxCNC distro possible?
What are the issues that linuxcnc is fighting in future proof ness ?
I’m not a programmer so this question is just one of interest.
  • spma
  • Junior Member
  • Junior Member
21 Mar 2020 18:32 #161017 by spma
Replied by spma on topic Embedded LinuxCNC distro possible?
@BeagleBrainz This is the most important one, I think, the problem that LCNC relies heavily in python2 and the fact that its EOL was 1/1/2020 ( Python2 EOL Countdown , info in python.org ) and Debian is currently removing python2 support .
@Bari thank you for that, I'll definitely look into it!
I know the main project is in a bit of a pickle, especially with the python upgrade thing....
I'm going to see if I can start helping on that!
Meanwhile I left this idea here, for further discussion.
Simão A.
The following user(s) said Thank You: BeagleBrainz
21 Mar 2020 18:50 #161018 by tommylight
Replied by tommylight on topic Embedded LinuxCNC distro possible?
I am aware of the massive changes from python 2 to 3 from the very beginning of it, but i could never find a reasonable explanation on ditching the backward compatibility. Then again, since i rarely use it, i am not the one to judge.
Time to create page: 0.092 seconds
