[SOLVED] Huge latency with PREEMPT_RT
- arvidb
- Thank you received: 158
31 May 2020 14:26 - 23 Jun 2020 05:16 #169554
by arvidb
[SOLVED] Huge latency with PREEMPT_RT was created by arvidb
I have a newly installed system following the
Debian 10.4 Buster Linuxcnc quick and easy install
guide.
latency-histogram looks like this:
arvidb@debian:~$ latency-histogram --nobase --servo 250000 --show
I believe most of the outliers are about 2 ms, so it seems I get about 5-10 of these delays each second. If I reset the values I immediately get a max of thereabouts again.
Now I have used this computer to run linuxcnc back in 2014 or thereabouts and I know I managed to get very good latency figures then, with 250 µs base thread.
Any idea where to begin to look? I don't have any of the rt* files under /dev mentioned in the Wiki Troubleshooting section - are these needed for RT_PREEMPT as well as for RTAPI?
Is the rtapi_app supposed to run with realtime scheduling? It seems it doesn't:
Anything else I should check?
arvidb@debian:~$ uname -a
Linux debian 4.19.0-9-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.118-2 (2020-04-29) x86_64 GNU/Linuxlatency-histogram looks like this:
arvidb@debian:~$ ls -l /dev/rt*
lrwxrwxrwx 1 root root 4 May 31 21:04 /dev/rtc -> rtc0
crw------- 1 root root 252, 0 May 31 21:04 /dev/rtc0
arvidb@debian:~$ ls -l /dev/RTAI_SHM
ls: cannot access '/dev/RTAI_SHM': No such file or directoryIs the rtapi_app supposed to run with realtime scheduling? It seems it doesn't:
arvidb 7522 5.7 0.3 62616 22760 pts/0 Rl+ 21:20 0:00 /usr/bin/tclsh /usr/bin/latency-histogram --nobase --servo 250000 --sh
root 7535 4.3 0.7 48580 48540 ? SLsl 21:20 0:00 /usr/bin/rtapi_app load threads name1=t_servo period1=250000
arvidb@debian:~$ chrt -p 7535
pid 7535's current scheduling policy: SCHED_OTHER
pid 7535's current scheduling priority: 0Anything else I should check?
Last edit: 23 Jun 2020 05:16 by arvidb. Reason: Mark as solved
- Thank you received: 5337
31 May 2020 14:46 #169560
Replied by PCW on topic Huge latency with PREEMPT_RT
2 ms is huge, Do you have all power management disabled in the BIOS?
Here's an older kernel on a similar system:
freeby.mesanet.com/e8500-4.4.1-rt5.png
but 4.19 should be similar
The following user(s) said Thank You: arvidb
- arvidb
31 May 2020 15:39 #169568
by arvidb
Replied by arvidb on topic Huge latency with PREEMPT_RT
- arvidb
31 May 2020 15:58 - 31 May 2020 15:59 #169572
by arvidb
Some further testing shows that the culprit was the EIST function:
Enhanced Intel SpeedStep
. With that turned off, but C4, C2 and C1E enabled and a few glxgears running, latency stays below 20 µs. Using Firefox to watch YouTube however still brings some spikes up to about 500-700 µs (but *much* rarer than the continuous 2 ms spikes I got with EIST enabled):
Last edit: 31 May 2020 15:59 by arvidb.
31 May 2020 16:57 #169577
Yes, I think Speed-step basically stalls the processor while it waits for the voltage
and clock speed to change so its a no-no for real-time
- BeagleBrainz
- Visitor
31 May 2020 20:30 #169603
by BeagleBrainz
Replied by BeagleBrainz on topic Huge latency with PREEMPT_RT
If you are going to isolate a core, you are best off isolating 2 cores and they should be on the same die.
- arvidb
02 Jun 2020 08:43 - 02 Jun 2020 08:53 #169803
by arvidb
BeagleBrainz: Isolating two cores on a dual-core machine without hyperthreading doesn't really make sense to me...?
It seems the remaining outliers happen when I switch focus to the Firefox window (regardless of contents; it's not really YouTube related as I first thought). Not every time, just once in awhile. Turning off the xfce compositor helped a bit by approximately halving the latency of the outliers - but it didn't reduce the number of them. Maybe the occasional 300-350 µs delay is okay for a 1 ms servo thread (no base thread)? Or I might just have to leave Firefox alone while running an NC program...
Maybe I should try some other window environment? Anyone else running xfce successfully? This machine's got an Radeon HD 3870 graphics card, running the radeon driver.
Edit: I should add that this will be a mixed EtherCAT (Omron G5 for X, Y, and spindle) and Mesa (Z - Yaskawa SGDA, and IO) system.
Last edit: 02 Jun 2020 08:53 by arvidb.
02 Jun 2020 09:36 #169808
It might be video board related.
Does the MB have built-in Intel video?
If so I would give that a try
- BeagleBrainz
- Visitor
02 Jun 2020 14:17 #169859
by BeagleBrainz
Sorry mate thought it was a quad core. If you have hyper threading enabled disable it.
Also try without any third party video drivers.
XFCE can help with latency.
Do a standard install of Mint 19.x with XFCE then use the kernel and packages from my repo, everything from there has been compiled on Mint so you won’t have any issues with dependencies.
Just use the standard X Windows drivers for your video card.
Try a PS/2 mouse and keyboard if you can, I have personally seen reductions in latency by using non USB keyboard and mouse, I use PS/2 myself rather than USB. USB wireless will mess up latency, actually I do all my latency tests without any wireless. If it is needed only enable it when not running linuxcnc.
If you’re still not getting the required results a new machine might be the only answer. Tommy usually has the answers to that one.
- arvidb
04 Jun 2020 11:57 #170103
by arvidb
PCW: No built-in graphics unfortunately. I do have another graphics card (that uses the amdgpu instead of the radeon driver) that I could use temporarily for testing though, if it turns out to be necessary.
BeagleBrainz: Thanks for trying to help.
* As I said, and as you can see from Intel's E8400 page , this is a 2-core CPU without hyperthreading.
* As I wrote, I'm using the radeon driver already (i.e. the default, in-kernel driver). No 3rd party drivers installed.
* As you can see from my previous message, I'm already running xfce.
* I'm actually already using a PS/2 keyboard on this computer, but I have no PS/2 mouse to try unfortunately. Also nothing wireless.
Do you have any specific reasons to believe another distribution (Mint) would help, despite running the same kernel, drivers and window manager on the same hardware? Redoing the install is a large undertaking since I'm using EtherCAT - I have to build everything from source. (It's great that you're eager to help, but it mostly feels like you're sending me on wild-goose chases by not taking time to understand the circumstances...)
Time to create page: 0.218 seconds
