BIOS settings (pictures)
  • txtrone
  • txtrone's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Oct 2020 12:24 #185855 by txtrone
Replied by txtrone on topic BIOS settings (pictures)
2 i would set that and the one bellow it to the same value to avoid resizing memory during work, so both at 64
Weird, the one below, which is 'DVMT Total Gfx Mem' has the following options:
Max
128m
256M
So there is no way to match it to 'DVMT Pre-Allocated'
  • Moderator
  • Moderator
12 Oct 2020 12:40 #185857 by tommylight
Replied by tommylight on topic BIOS settings (pictures)
:pinch:
  • txtrone
  • Platinum Member
  • Platinum Member
12 Oct 2020 12:49 #185860 by txtrone
I wonder what 'OM' stands for in the 'DVMT Pre-Allocated' ???
  • wolfram
  • wolfram's Avatar
  • Visitor
  • Visitor
07 Apr 2024 05:40 - 07 Apr 2024 05:41 #297743 by wolfram
Replied by wolfram on topic BIOS settings (pictures)
For plasma i use ethernet, saves a lot of trouble with cabling and shielding.
What Mesa cards do you use for plasma? Thanks.
Last edit: 07 Apr 2024 05:41 by wolfram.
  • Moderator
  • Moderator
07 Apr 2024 10:42 #297751 by tommylight
Mesa 7i92 but lately switched to 7i96, no need for relays and voltage regulators anymore. This makes things very, very simple.
The following user(s) said Thank You: wolfram
Time to create page: 0.856 seconds
