preferable parts of PC
14 Sep 2010 09:49 #4191 by Gelar
preferable parts of PC was created by Gelar
i'd like to change pc that controls machine. what manufacturers are better for all parts of the pc:
1. cpu - intel or amd?
2. graphics nvidia or ati?
3. MB?
4. sata or ide?
5. are modern laptops really that bad (but very convenient)?
14 Sep 2010 11:28 #4194 by Rick G
Replied by Rick G on topic Re:preferable parts of PC
Hello,
You might start here...
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Hardware_Requirements
Rick G
21 Sep 2010 06:34 #4267 by Gelar
Replied by Gelar on topic Re:preferable parts of PC
yep, I saw that article. i thought someone has generalized experience about hardware that is being sold (made) now, not 2-3 years ago. especially about notebooks. I have no possibility to test a wide range of hardware.
21 Sep 2010 11:41 #4272 by andypugh
Replied by andypugh on topic Re:preferable parts of PC
the D510MO board from Intel is popular. The parallel port is on a ribbon-cable header which might be a slight disadvantage (though it is a slight advantage if you are using a Mesa 7i43).
Cost is about $75 for the board+CPU. You need memory and a HD (8GB SSD works well for EMC2). For the Power supply a PicoPSU running of the CNC system 12V makes sense. You then end up with a very compact system you can fit in the corner of the machine cabinet.
LiveCD install of 10,04 gives latency of 7000 with no fiddling.
Time to create page: 0.062 seconds
