Linux-Debian-11-Bullseye-Rtos-5.10.0-5-rt-amd64 Download
5 years 6 months ago #205915 by CNC4Life
Looks like we didn’t quite get to the finish line. The image you provided wouldn’t install/update grub.
5 years 6 months ago #205918 by scotth
I had no luck with the direct download, working on the DVD version now.
Scott
5 years 6 months ago - 5 years 6 months ago #205920 by Grotius
@ CNC4life,
I googled on the grub error, there's a lot info about this error. Some say it has to do with bios, partioning, etc.
At the moment i don't know how you can solve this. Have to study this error first.
I tested the version on dvd, not on usb.
@ Scotth,
You mean the sourcforge direct download? I mentioned last time it was hard to get the download running.
Or do you mean something else?
I have an idea. You both can test a new distro today.
On my pc it installed 2 times with succes. I am curious if this release will work at your pc's.
Will bring a new topic about the upcoming release in a few minutes.
Last edit: 5 years 6 months ago by Grotius.
5 years 6 months ago - 5 years 6 months ago #205925 by CNC4Life
The image with grub/not mounting the USB is: cdimage.debian.org/cdimage/bullseye_di_a...pha3-amd64-DVD-1.iso
I was able to get the LinuxCNC-2.8.0.iso issue installed and I was able to backport to the 5.10 kernel which fixed my video issue with X.
Last edit: 5 years 6 months ago by CNC4Life.
5 years 6 months ago #205930 by Grotius
@ CNC4Life,
Hmm. That's an almost official 3rd generation release. I gave the link to test your pc with an orginal debian iso. After all, not
a very bad idea.. ..
Inside the iso i think they forgot to do "sudo update-grub" at the end of creating the iso image. Just before umounting chroot.
Another methode is adding these inside the iso, for example during a live-build :
sudo apt-get install grub-common grub2-common grub-pc-bin efibootmgr grub-efi-amd64 \ grub-efi-amd64-bin grub-efi-amd64-signed grub-efi-ia32-bin \ libefiboot1 libefivar1 mokutil shim-helpers-amd64-signed \ shim-signed-common shim-unsigned \
Did you had displayport problems with the lcnc iso?
5 years 6 months ago #205994 by andypugh
Areyou deperate to run Bullseye, or do you just want to run LinuxCNC?
If you just want LinuxCNC, then can I recommend the LiinuxCNC installer?
www.linuxcnc.org/downloads/
Time to create page: 0.380 seconds
