5 years 2 months ago #217164 by Cncninja
skr1.4 motion is working but the other i/o is not, I was hoping to use the input switches as wired and use the bed heater as M3 and fan output as an M8 is any of the i/o mapped in the Hal other than the motion? Also, the 2209 has a home feature with a stall warning signal that goes high we could wire back into the homing switched but the problem is 2209 needs a enn toggle to start moton after the stall.
5 years 2 months ago #217169 by Cncninja
I would like to make a mini mill config so people can plug and play with the grbl boards used by so many on the 3018 CNC mills. they have plug-and-play connections with 3D printer boards(skr1.4) steppers and homing switches. But a mill needs M3 for spindle on-off and a 0-5v for speed control or those with 24v dc spindles us the bed heater fet and PWM speed control also M8 for air/coolant and a probe input. the SKR has all this it just needs to be mapped in the config for a Mill vs printer config
bed heater pwm = to spindle M3 as PWM (dc spindle), also to a digital pin on/off for ext spindle control
extruder 2 hotend to 1~5v pwm for spindle speed control
hotend heater to = M8 coolent no pwm just on off
there are 2 analog thermistor inputs that could be mapped to use with external spindle and feed overrides (0-5k pots)
I really think this would have a big splash with current grbl users to make a mill version I can easily demo it with my channel and FB pages
5 years 2 months ago #217172 by Bari
If they only had a GPU :)
We used the original Allwinner A10 or A20 >5 years ago on the Cubieboard with Xenomai and we had decent stepping without any integrated micro.
Lots of this just boils down to building u-boot, the kernels and configs properly vs just random slapped together shit that you are supposed to edit by hand later.
5 years 2 months ago #217176 by cakeslob
but its an fpga, so you could just build a gpu. but yeah good point i didnt think of that. looks like theres one xilinx zynq that has a mali400 on it . i mean i dont need fancy graphics, the fanuc i use everyday doesnt have any fancu graphics, but i dont not want fancy graphics
but anyways, back to remora
heres my fast and dirty setup . no fancy pcb but my bitchin all-purpose utilitarian cable, now with unnecessary length! colour coded as per the manual to minimize those looming wiring errors! Tired of short circuits? All the connectors on The Regular Ass Cable are insulated to save you from your self! All the flexibility of a cable, while still maintaining the freedom to plug it in backwards(its a feature)! Are you so lazy that crimping is the only thing between you and success? You can buy pre-crimped for mere pennies per wire!
5 years 2 months ago #217180 by Cncninja
So making a 4 axis mill profile using skr1.4. attached is a somewhat working config for the skr, the remora xyza need some work m3 is coming out m5 etc
File Name: Mill4axis.zip
File Size:4.38 KB
5 years 2 months ago #217269 by mhel
@gtt38
I don't supposed you're waveshare dev board came with a network phy (i.e. DP83848C) ?
Do you want to tinker with Remora over ethernet?
See if it's viable, worth spending more time on it?
Time to create page: 0.500 seconds
