- Thank you received: 234
I think what you said makes some sense, because my situation appears after half a minute of running, and occasionally earlier, but I’m sorry I don’t quite understand (have several grounds around each signal wire between the skr and rpi.), I should How to accomplish it.I would be grateful if you could share your wiring diagramcould be noise getting into the spi wires.
I ran my spi wires in rg174 coax to keep the noise down.
But that is overkill.
The better way is to keep the run as short as you can and have several grounds around each signal wire between the skr and rpi.
