5 years 2 months ago - 5 years 2 months ago #218950 by scotta
"Hello world" on the SKR2 is working! Thank you Rommel!!
Just need to figure out why the following is not working so we don't need to define a Serial object in the code and use a plain old printf.
"platform.stdio-baud-rate": 115200, "target.stdio_uart_tx": "PA_9", "target.stdio_uart_rx": "PA_10"
I've pushed the working code to the testing repo:
github.com/scottalford75/SKRV2-Mbed-OS5
Last edit: 5 years 2 months ago by scotta.
5 years 2 months ago #218951 by mhel
That's great!
I'll try to help when I can, I'm just a hack :)
Mbed is still very foreign to me.
What do you think of oring
USE_PLL_HSE_XTAL | USE_PLL_HSI
looking at system_clock.c, it looks like it will fall through and end up using HSI clock ?
5 years 2 months ago #218952 by mhel
smoked my SKRv1.5 by putting a driver in backwards in a rush. Probably will need to start again with the SKR2 when it's up and running.
That sucks, I guess it happens.
5 years 2 months ago #218953 by scotta
Ok, got the standard printf working.
We now have a working platform to start porting Remora to STM32 with Mbed and the standard SKR bootloader. Rommel, thanks once again!! I've wasted hours but the system_clock.c change was the key.
Repo updated.
5 years 2 months ago #218954 by mhel
5 years 2 months ago #218955 by scotta
That's great!
USE_PLL_HSE_XTAL | USE_PLL_HSI ? looking at system_clock.c, it looks like it will fall through and end up using HSI clock ?
I adopted a working target profile. We can remove USE_PLL_HSI and see what happens. The docs say that line should first try to enable the High Speed External crystal before falling back to the Internal crystal.
Time to create page: 0.544 seconds
