4 years 6 months ago #240531 by cakeslob
For the ethernet, its spi as normal, PC_4 to reset on the whiz, or PC_4 to interrupt ? Also, do we need to change anything in the config file for this? like, do we remove the reset pin section, or do we add something?
Also, I dont know what Im doing with the docs, I though the pages would be added to sidebar/hardware section, but they did not add, I do not know where I went wrong on this.
4 years 6 months ago #240615 by scotta
I'll need to do a little work to get the W5500 back up and running. The LinuxCNC Ethernet component has been modified for the NVEM board.
Regarding the docs, yes, not sure why the new sections aren't updating as things look correct in your modifications.
4 years 6 months ago #240693 by cakeslob
thats cool, i know you go other things on the go, me n my whizz are ready when you are. the main reason was im trying to mock up a w5500 board thats fits into the wifi adapter spot, because I think that would be pretty slick. it looks like this wifi adapter footprint is becoming more standard, and on more boards, so i thought it would be cool, and make for a clean, universal setup
4 years 6 months ago #240696 by eng
did you manage to do any tests with the w5500 with the Black F407VE? I would be very happy if this were possible.
4 years 6 months ago - 4 years 6 months ago #240715 by gtt38
The Black VE with w5500 work very good, I tested yesterday on a Nucleo F411 too.
edit : btw I updated to OSmbed 6 as I’m not using any LPC targets anymore. It works very good, even if the w5500 library is made for OSmbed5
Last edit: 4 years 6 months ago by gtt38.
4 years 6 months ago #240716 by eng
Could you tell me your settings to be able to study with the Black VE with w5500, here in Brazil it is 5 times cheaper than a raspberry.
