- Thank you received: 27
In the work I have been doing on the NVEM Ethernet version of Remora I have now been able to store and retrieve the config.txt file contents to and from the Flash memory of the STM32. I've been working on this as there is no SD card on the NVEM and we can send the config over Ethernet to the board.
Is this a feature, the Flash storage that is, that people would use on 3D printer controller boards. This would allow the removal of the SD card. The only time the SD card would need to be inserted would be for firmware or config updates.
