3 years 5 months ago - 3 years 5 months ago #272226 by drewnabobber
It's a bit easier to just use something like a W5500 chip directly via SPI (Scott already has code working for this).
With FlexiHAL we have a small add-on module in the works so that people aren't reliant on a Pi even though they are getting easier to find - we have not yet found another SBC that has adequate GPU driver support for Probe Basic.
Currently working on DMA transfers (even just using IRQ is a reasonable improvement), again just following on from the work that Scotta has already done.
Last edit: 3 years 5 months ago by drewnabobber.
The following user(s) said Thank You: cakeslob
3 years 4 months ago #272853 by Bari
$9 board: linuxgizmos.com/milk-v-duo-is-a-9-00-ris...y-embedded-computer/
milkv.io/docs/duo
github.com/milk-v/duo-manifest
milkv.io/duo
The Milk-V Duo is a small RISC-V embedded platform capable of running Linux and RTOS. The low-cost device features up to 26x GPIOs, optional 10/100Mbps Ethernet support and integrated with a H.264/H.265 video compression encoder and ISP.
The product page indicates that his Milk-V Duo is based on the SOPHGO CVITEK CV1800B (C906 @1Ghz + C906 @700MHz) System-on-Chip with up to 64MB DDR2 memory. The company indicates that the Duo integrates CVITEK TPU for smart detection and supports H.264/H.265 video encoding, up to 2880×1620 @20fps.
3 years 4 months ago #273884 by cakeslob
github.com/sbmarcom/CNS_Comp/tree/cns_gui/GasControl
github.com/sbmarcom/CNS_Comp/tree/cns_gui/cns_comps/remora
what do you think these guys are doin?
They have something going on with with remora comp and an stm32f103 bluepill board, but i didnt see any firmware posted. I sent them an email a few weeks ago but no reply
3 years 4 months ago #273887 by phillc54
3 years 3 months ago - 3 years 3 months ago #275287 by virencq
Greetings dev,
I have NucleoF446ZE board and tried to flash relevant firmware along with config.txt.
I have also connected SPI pins as suggested in docs.
Starting linuxcnc, axis screen lives but doesn't comes out of e-stop.
When I run in terminal I got error
Bad SPI payload =0
Last edit: 3 years 3 months ago by virencq.
3 years 3 months ago #275295 by cakeslob
Hey virencq, can you show me which firmware/docs you were using?
I have a nucleo specific set of documents and firmware, but its specific to the Nucleo64 STM32F446RE. I havent tested it with the 446ZE, I have to check some pin compatibility between the RE and ZE. I will test with my special nucleo firmware , but I made some changes regarding (lack of) pins for the 446re, so it may need some minor changes. The firmware might work with ZE but I doubt it compile properly
In the meantime, if you want to fool around with it, here are the nucleo repos ive been working on
github.com/cakeslob/Remora/tree/nucleo_sd
github.com/cakeslob/Remora/tree/nucleo_static
github.com/cakeslob/Remora-docs/blob/nuc...rdware/nucleo446.rst
