In main.c- RemoraComms comms(ptrRxData, ptrTxData, SPI1, PA_4);
Where you had PE_9, that would be the interupt pin, you should be able to leave that as PA_4, but if you want to change it, you need to change the interupt pin in the comms driver
github.com/cakeslob/Remora/blob/nucleo_s...omms/RemoraComms.cpp
right now its able to be PA_4, PB_1 and PB_6
I tested it with a software interupt pin and on other pins, it didnt give me a communication data error but it did not connect either.
the PRU reset pin is set in the board config here
github.com/cakeslob/Remora/blob/nucleo_s.../board_config.h#L103
I currently have it at PB_4 because it was beside PA_4
here is where you would do any pin changes for your steppers and such
The bin file is through USB, but config.txt versions require an SD card. this version, if you want to change pins you need to change board_config file and recompile.
so, with the firmware i uploaded, the pins are
(PA_7, PA_6, PA_5, PA_4); // mosi, miso, sclk, cs with PB_4 as reset pin, so you dont need to change anything to run with those settings. There is something wrong though with 446ZE which is not happening on 446RE
I will test more after work
