PC is freezing when running glxgears after several hours
- thang
- Thank you received: 11
11 May 2021 03:28 #208518
by thang
PC is freezing when running glxgears after several hours was created by thang
My testing system include:
+ CPU Intel celeron J1900
+ 4 gb ram
+ ssd 120gb
+ Ubuntu os with preempt rt 4.9
It's freezing when i run glxgears after several hours and i think this problem relate to realtime kernel because it happen only when i running system under realtime kernel.
If anyone have exp about this problem?
+ 4 gb ram
+ ssd 120gb
- BeagleBrainz
- Visitor
11 May 2021 03:51 #208520
by BeagleBrainz
Replied by BeagleBrainz on topic PC is freezing when running glxgears after several hours
Is it a complete lockout or just a lockout of the GUI.
Can you ping or ssh into the affected machine after it freezes ?
Have you looked into any of the logs after a reboot ?
Seems like a common problem with the J1900 with or without a RT kernel.
You could try and modify the kernel command line by adding this
intel_idle.max_cstate = 1Please Log in or Create an account to join the conversation.
- thang
11 May 2021 09:22 #208530
by thang
Replied by thang on topic PC is freezing when running glxgears after several hours
tks for the advice, i will try it
- thang
12 May 2021 09:07 - 12 May 2021 09:08 #208613
by thang
So my PC is laggy and not complete freezing, i still can move mouse, ssh and ping from other PC, it just drop FPS and CPU run 100%.
I modified the kernel cmd line in Grub but nothing change
Last edit: 12 May 2021 09:08 by thang.
Time to create page: 0.095 seconds
