Is this a good PC
  • htdave
  • htdave's Avatar Topic Author
  • Senior Member
  • Senior Member
14 May 2021 07:20 #208783 by htdave
Is this a good PC was created by htdave
Is this a decent PC to use with LinuxCNC and Mesa?
www.auspcmarket.com.au/systems/mini-pcs/...m-7th-gen-processor/
14 May 2021 14:18 #208808 by andypugh
Replied by andypugh on topic Is this a good PC
I think that some folk have used the NUC successfully.
I tend to use a bare Mini-ITX motherboard in the same box as the other boards, treating it as just one more component. There are many boards available now that take 12V DC input, and some that will work from 24V too . (Note: I have not tried that specific board, I am running a JNF9C-2800 in my lathe)
I also have a Beelink BT3 Mini-PC (like a NUC, but cheaper) which appears to work happily with a Mesa ethernet board.
14 May 2021 19:28 #208843 by Clive S
Replied by Clive S on topic Is this a good PC
Andy would this be the one
www.dx.com/p/beelink-bt3-pro-mini-pc-int...95.html#.YJ7L9ejYogo
14 May 2021 20:01 #208849 by andypugh
That's the one. But bear in mind I only bought it as it was the cheapest Intel PC on Amazon that day, with UEFI, and I wanted it purely to test the LinuxCNC ISO. (it was on special offer at £85 that day).
But, it is rather a nice little package.
14 May 2021 21:36 #208860 by Clive S
Thank you Andy. I know you don't generally give any recommendations and I am not treating it as one.
But I might just give one a try. B)
  • htdave
  • Senior Member
  • Senior Member
15 May 2021 22:13 #208988 by htdave
Replied by htdave on topic Is this a good PC
That looks like exactly what I am after. I have just ordered one:)
  • htdave
  • Senior Member
  • Senior Member
03 Jun 2021 06:51 #211066 by htdave
What version of linux and Lcnc are you using?
I tried the standard install, but it hung on network configuration.
I tried mint 20, but I lost wifi after RT kernel, and it crashes frequently
06 Jun 2021 22:49 #211373 by andypugh
Stock LinuxCNC install ISO, but removing wicd and installing nm-tray.
The following user(s) said Thank You: htdave
Time to create page: 0.139 seconds
