Linux graphical interface disappeared
14 Jun 2021 17:06 #212038 by Doogie
Replied by Doogie on topic Linux graphical interface disappeared
sounds like you messed up your xorg.conf file so maybe try recofiguring X and try again.
sudo dpkg-reconfigure xserver-xorg
  • Mr. Mass
  • Mr. Mass's Avatar Topic Author
  • Senior Member
  • Senior Member
14 Jun 2021 18:01 #212042 by Mr. Mass
Replied by Mr. Mass on topic Linux graphical interface disappeared
You on your way to being a Linux master, you have the right attitude.
Thanks for the kind words, I am always happy to learn something new, and looks like lunixcnc and linux in general a lot to learn.
I use the terminal.
I have no problem with terminal, I have problems how exactly it all works. BTW, command line was reminded pleasant nostalgic memories about my first computer zx spectrum. I was fooling around with this computer as a child, even tried to program something on it.
I'm tried to add this execute permission bit, but still had same issue.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
14 Jun 2021 18:27 - 15 Jun 2021 00:47 #212045 by BeagleBrainz
Replied by BeagleBrainz on topic Linux graphical interface disappeared
No need to use sudo as it doesn’t modify any files.
Also it would appear it requires xinput to run.
sudo apt-get install xinput
If you look at the last line of the error, the error report is it can't find "/usr/bin/xinput"
Last edit: 15 Jun 2021 00:47 by BeagleBrainz.
  • Mr. Mass
  • Senior Member
  • Senior Member
15 Jun 2021 04:34 #212094 by Mr. Mass
Thank you very much for this tip, finally it worked. This program much better than "xinput_calibrator". I had issue with mirroring X axis and with "xinput_calibrator" I had to manually fill in the "Coordinate Transformation Matrix" in my case, but this program did everything by itself perfectly! Thanks a lot again!
The following user(s) said Thank You: BeagleBrainz
  • BeagleBrainz
  • Visitor
  • Visitor
15 Jun 2021 05:25 #212097 by BeagleBrainz
No worrie, my screen was originally mirrored in the Left - Right & Up - Down and it was just all out of whack, xcalibrator was so much more easier to get a great solution.
17 Jun 2021 21:58 #212296 by andypugh
Replied by andypugh on topic Linux graphical interface disappeared
worldofspectrum.org/archive/software/gam...eb-mc-lothlorien-ltd
17 Jun 2021 22:20 #212298 by tommylight
18 Jun 2021 15:34 #212340 by andypugh
:woohoo: :woohoo: :woohoo:
I was 16 at the time. I bought my first motorcycle with the proceeds of the sale :-)
  • BeagleBrainz
  • Visitor
  • Visitor
18 Jun 2021 22:23 #212359 by BeagleBrainz
OK Andy, is there anything you can't do ? :laugh:
You haven't got a BSB Championship up your sleeve as well ?
Time to create page: 0.134 seconds
