TB6600 and new motherboard.
01 Jul 2021 22:38 #213459
Replied by andypugh on topic TB6600 and new motherboard.
Have you tried longer step times?
- MagicMarcus
02 Jul 2021 09:31 #213484
by MagicMarcus
Replied by MagicMarcus on topic TB6600 and new motherboard.
Yes I tried change longer times manualy - Z axis don't move.
I reinstaled operating system.
I noticed that every time I save StepConfig, the times go back to 1. I changed it manually to 10000 and Z axis doesn't move.
- Thank you received: 7488
02 Jul 2021 10:50 #213486
Replied by tommylight on topic TB6600 and new motherboard.
Step times need to be changed in the .INI file, not n the .HAL file.
Also the step time will depend on the base period if using one, so using a slower base period might help.
Not sure what is going on but if other axis are working but Z is not, check the drive and motor wiring then switch the Z drive and motor to X or Y, if it still does not work = change the drive or in rare cases the motor.
- MagicMarcus
02 Jul 2021 11:08 #213487
by MagicMarcus
Hmmm, where is it in .INI file?
02 Jul 2021 13:22 #213493
Oh, using parallel port, so in the hal file change the reset time to 10000, then in the ini file change the base period to 100000.
Did you try connecting it to X or Y?
- MagicMarcus
02 Jul 2021 17:09 - 02 Jul 2021 17:13 #213503
by MagicMarcus
In INI file base period is 100000.
Hal file doesn't have reset time position.
I tested everything - wires, I switched X, Y, Z axis on motherboard.
I have X axis with M542 driver, Y asis 2x M542 driver. Only Z axis I have TB6600 driver which doesn't work on any axis on motherboard ports.
X and Y work on motherboard X, Y, Z ports.
Z motor works on M542 driver.
Last edit: 02 Jul 2021 17:13 by MagicMarcus.
02 Jul 2021 23:09 #213513
They can just fail. The TB6560 fails as a hobby. The 6600 is meant to be better. But can your observations be explained by a failed driver?
@tommylight: His HAL is coming out wierd, hard-coded to 1 for step and space and no reset. Possibly a unit confusion in the date entered, but the INI is not involved.
Ah, so you are saying that the TB6600 driver does not work at all? Or that is works, but not with LinuxCNC?I have X axis with M542 driver, Y asis 2x M542 driver. Only Z axis I have TB6600 driver which doesn't work on any axis on
03 Jul 2021 09:58 #213546
Yup noticed that, but i would not change the timings in hal, back in 2.7 while it was in beta i did change that and it had some issues with it. Reset line can be added in hal, but this seems like a driver issue since 2 other drives are working.
- MagicMarcus
03 Jul 2021 10:08 - 03 Jul 2021 10:09 #213549
by MagicMarcus
TB6600 driver worked fine on previously old motherboard - for a moment I got back to old harware configuration (with the same LinuxCNC version) and every axes worked fine. I have few TB6600 and all from they not work with new motherboard.
Last edit: 03 Jul 2021 10:09 by MagicMarcus.
03 Jul 2021 10:24 #213551
That might be due to 5V on old and 3.3V on new motherboards.
The easy way around that is to use a USB cable to provide 5V to drive inputs and wire the inputs for common 5V.
New TB6600 drives ( they use a different chip inside) work with 3.3V always, not sure about the real 6600 ones, i do not think i have any left to test.
Time to create page: 0.099 seconds
