- Thank you received: 11
ahh good to knowMalteS wrote: I did look at the code here: github.com/SebKuzminsky/hostmot2-firmware-beaglebone and believe this is an attempt to load FW to the PRUs via hostmod2. There are some hard coded valued in the main.c and my impression is that this was an attempt but is far away from the functionality provided by the machinekit driver (e.g. it seems to do only PWM out on hard coded PINs)
If you want to experiment with the PRU driver then I created a test branch of LinuxCNC with it included.
If you are building from source then just:
git checkout andypugh/bb_pru
And compile as usual.
I haven't tested it which is why it has not yet been merged with the LinuxCNC mainline.
