my own designed 7i92 board not work
  • mahdi2001h
  • mahdi2001h's Avatar Topic Author
  • Junior Member
  • Junior Member
06 Oct 2021 15:40 #222373 by mahdi2001h
Replied by mahdi2001h on topic my own designed 7i92 board not work
No, the card should respond to pings regardless of what's in the EEPROM,
because the 192.168.1.121 address is in the FPGA configuration, not the EEPROM.
I suspect a hardware issue. If you set the IP address jumpers to the
bootp setting (Up/Down on a 7I92) does the card transmit once per second?
(this should be visible on the link lights)
Actually I should step back a bit, before you run mesaflash,
have you programmed the FPGA via JTAG? (this is necessary to bootstrap the card)
yes! it's transmitting
and I programmed FPGA , in boot the user led blinked
06 Oct 2021 17:01 #222380 by PCW
Replied by PCW on topic my own designed 7i92 board not work
OK, when you ping the card, do the user LEDs count?
  • mahdi2001h
  • Junior Member
  • Junior Member
06 Oct 2021 17:07 #222382 by mahdi2001h
yes , but ping show packet loss
06 Oct 2021 17:39 - 06 Oct 2021 17:39 #222384 by PCW
It sounds like its transmitting (you can verify with tcpdump)
Are you using a recent bit file?
Bitfiles before May 2018 do not mask the MAC address from the EEPROM
so an uninitialized EEPROM will result in a 0xFFFFFFFFFFFF MAC address
This may result in lost packets if the go through a switch (Bitfiles after May
2018 mask the MS byte so you get a valid MAC address even
berfore the EEPROM is initialized.)
Last edit: 06 Oct 2021 17:39 by PCW.
06 Oct 2021 18:35 #222387 by robertspark
Replied by robertspark on topic my own designed 7i92 board not work
 copied a 7i92?
... but run a fiber laser in another post... yup just for personal use
  • mahdi2001h
  • Junior Member
  • Junior Member
06 Oct 2021 18:48 #222388 by mahdi2001h
 copied a 7i92?
All I can say is that Peter's behavior is really respectable
06 Oct 2021 20:28 #222398 by robertspark
I would have said amazing and extremely supportive
06 Oct 2021 20:29 #222399 by tommylight
Replied by tommylight on topic my own designed 7i92 board not work
 copied a 7i92?
You noticed ... :)
Although i do understand (probably) as he seems to be living in a country worse than mine (i have my doubts), so getting a Mesa card is pretty much like wining the lottery.
06 Oct 2021 20:32 #222400 by tommylight
+1
  • mahdi2001h
  • Junior Member
  • Junior Member
23 Nov 2021 09:17 #227386 by mahdi2001h
I received the code from mesanet and compiled and programmed (with ise)
after trying some idea , I realized the board received packet but not response to them.
i send several packet with UDP sender to board but not know the board ip.
when i send data through ip 192.168.1.255 port 27181 the led blinked (that shows the packet received)
but when send to 192.168.1.121 but Did not answer.
Time to create page: 0.106 seconds
