Very high latency on Intel NuC10 (Core i5-10210U)
- jrbloom
- Topic Author
4 years 10 months ago #229754
by jrbloom
Very high latency on Intel NuC10 (Core i5-10210U) was created by jrbloom
Hi all.
I am trying to setup Linux CNC on a CometLake(CML) based Intel NuC10. This is a very recent Core-i5 based system, not a low-power NuC). My intention is to run this with a mesa 7i92, so don't need fast software stepping.
The latest linuxcnc livecd doesn't boot to the GUI out of the box due to the 4.19 kernel not having support in i915 for CML (which didn't land until around kernel 5.2). To fix this I upgraded the kernel to 5.10.0-0.bpo.9-rt-amd64 from a text login, and now have a working desktop.
I'm now able to run the latency test, but it is really dire, with Max Jitter ~16ms (16000000ns).
I did do some trawling of the docs to try to improve this, and have disabled pretty much everything in the BIOS, to no avail.
Also attempted to run smictl but it looks like that is pretty much defunct these days because it uses iopl, which does work on modern systems ( man7.org/linux/man-pages/man2/iopl.2.html ).
Is this kind of jitter typical of recent systems? I feel it cannot be since that would imply that linuxcnc is rapidly backing itself into a corner, and will eventually not be useable unless we're lucky enough to have access to ancient h/w.
Am I wasting my time trying to deploy this, even with h/w stepping?
Thanks,
Jon
Thanks,
Jon
- jrbloom
- Topic Author
4 years 10 months ago #229759
by jrbloom
Replied by jrbloom on topic Very high latency on Intel NuC10 (Core i5-10210U)
Ok, I did some more digging. The following thread:
25927-reducing-latency-on-multicore-pc-s-success
recommends using isolcpus on the kernel boot line. For my configuration, with a 4 core CPU, I added isolcpus=3 to /etc/default/grub, ran update-grub and rebooted. My Max Jitter has now been slashed to j194us. Still too high, but I am feeling more optimistic
I will keep trawling the Forum for more tips, but in the meantime if anyone has any suggestions for bringing this down further I'd be very grateful.
Thanks,
Jon
Thanks,
Jon
- 0x2102
- Thank you received: 80
4 years 10 months ago #229763
by 0x2102
Replied by 0x2102 on topic Very high latency on Intel NuC10 (Core i5-10210U)
For a 4 core CPU you would do isolcpus=1,2,3
You can these kernel parameters as well:
isolcpus=1,2,3 intel_idle.max_cstate=0 processor.max_cstate=0 idle=poll
- jrbloom
- Topic Author
4 years 10 months ago #229765
by jrbloom
Thanks a lot. That's brought it down to around 90us
Time to create page: 0.090 seconds
