Compiling realtime kernel
- Tady
- Thank you received: 11
I have been trying to compile a 5.14.2 version kernel with real time capabilities.
After some problems it compiled but I cannot boot it. GRUB says that kernel does not support efi handover
There is little info about this problem
On this page someone suggested to change settings in the menuconfig but I do not have these settings
stackoverflow.com/questions/40344484/can...ompiled-linux-kernel
It has been a very long time since I last compiled a realtime kernel. But this was never an issue
- Tady
- robertspark
- Thank you received: 216
if you are running a debian OS you can just install a RT kernel
sudo apt install linux-image-rt-amd64
or one of the alternative rt kernels.
packages.debian.org/search?keywords=linux-image-rt
- Tady
- ALittleOffTheRails
- Visitor
Yeah first time with EFI can be a bit tricky to begin with.
- Tady
Is run in place working on jammy? so I don't waste time
- Thank you received: 4149
That used to be the case. Brings back horrific memories...Well I was under the impression that you need to build your self a RT kernel ... At least that how I used to do it a few years ago
- Tady
./configure --with-realtime=uspace
checking for python build information...
checking for python3.10... python3.10
checking for main in -lpython3.10... no
checking for main in -lpython3.10m... no
checking for python3.9... (cached) python3.10
checking for main in -lpython3.10... (cached) no
checking for main in -lpython3.10m... (cached) no
checking for python3.8... (cached) python3.10
checking for python3.7... (cached) python3.10
checking for python3.6... (cached) python3.10
checking for python3.5... (cached) python3.10
checking for python3.4... (cached) python3.10
checking for python3.3... (cached) python3.10
checking for python3.2... (cached) python3.10
checking for python3.1... (cached) python3.10
checking for python3.0... (cached) python3.10
checking for python2.7... (cached) python3.10
checking for python2.6... (cached) python3.10
checking for python2.5... (cached) python3.10
checking for python2.4... (cached) python3.10
checking for python2.3... (cached) python3.10
checking for python2.2... (cached) python3.10
checking for python2.1... (cached) python3.10
checking for python... (cached) python3.10
results of the Python check:
Binary: python3.10
Library: no
Include Dir: no
checking for python3.10... /usr/bin/python3.10
checking for python3... (cached) /usr/bin/python3.10
checking for a version of Python >= '2.1.0'... yes
checking for a version of Python >='3.6'... no
configure: error: this package requires Python >='3.6'.
If you have it installed, but it isn't the default Python
interpreter in your system path, please pass the PYTHON_VERSION
variable to configure. See ``configure --help'' for reference.
This is the crap that chased me to Debian 10 Bullseye. No more Python fights and no need to compile the kernel.
Master branch requires 3.7 or higher as used by Buster. Mint and others use an earlier version.
Bullseye uses 3.9
