  • scotta
  • Platinum Member
  • Platinum Member
15 Jan 2022 21:04 #231933 by scotta
Hmm think it would be possible to send a config over ethernet?
so you would have a config file located in your linuxcnc config folder then sets the values.
But i think for getting off the ground fast just setting it for most other peoples use case would be better.
I myself do have a few st-links in a drawer somewhere if i needed to make changes.
Whats the part number on the optos?
That would be a neat way of doing it, just no idea at the moment how to implement it. I'm just now getting into how to configure the STM32F207 for ethernet with the LAN8720 PHY that is on the board. On the learning curve at the moment.
15 Jan 2022 21:18 #231935 by cakeslob
There is an unmarked IC on the board which I'm suspicious is an EEPROM.
good good, this will work for 3d printers as well, but how would you do this....something like how the 3dprinter configs work (i dont know how that is anyways)? like some kind of hard coded config based on board target, then load to i2c/spi eeprom on initialization, then change config over ethernet/serial? or something like a blank slate config thats configured from hal? sorry, i dont know how it really works just brainstorming.
  • ALittleOffTheRails
  • ALittleOffTheRails's Avatar
  • Visitor
  • Visitor
15 Jan 2022 23:04 #231961 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I'll keep watch of this.
If I can find one at the right price I'll grab one.
  • scotta
  • Platinum Member
  • Platinum Member
15 Jan 2022 23:24 #231966 by scotta
I was pretty happy with the price on Aliexpress. Got the 6 axes NVEM with the NVMPG for just under $200 AUD delivered with taxes etc.
The MPG with TFT display will be another project... need to reverse engineer the serial comms protocol and build that as a Remora module.
  • scotta
  • Platinum Member
  • Platinum Member
15 Jan 2022 23:25 - 15 Jan 2022 23:26 #231968 by scotta
This mornings effort. Getting ethernet up and running. First step to check the PHY connections.
Last edit: 15 Jan 2022 23:26 by scotta.
  • scotta
  • Platinum Member
  • Platinum Member
15 Jan 2022 23:28 #231969 by scotta
Configured the LwIP in STM32CubeIDE with a static IP address. The PHY address is important! I tried an address of 0 initially as per some online info, but no go. With the default address of 1, I was successfully able to ping the controller board! That was easier than I thought :-)
  • scotta
  • Platinum Member
  • Platinum Member
15 Jan 2022 23:38 #231970 by scotta
I'm contemplating doing this version of Remora in STM32CubeIDE rather than Mbed Studio as this will be specific to the NVEM board with the STM32F207.
Thoughts?
The following user(s) said Thank You: tuzki
  • scotta
  • Platinum Member
  • Platinum Member
16 Jan 2022 00:04 #231973 by scotta
The LinuxCNC Remora-eth component talks to the controller board via ethernet UDP. A simple UDP server was setup to test. The NVEM board is successfully replying to UDP packets.
The following user(s) said Thank You: phillc54, tommylight, tuzki, AlessandroEmm, ALittleOffTheRails
  • Visitor
  • Visitor
16 Jan 2022 00:17 - 16 Jan 2022 00:33 #231976 by ALittleOffTheRails
Like this ?
www.aliexpress.com/item/1005002272437121...4c56a860dd7b07510627
I would only want 3 axis for my lathe.
If you were ever to design your own hardware I'd be happy to help out with a few beer tokens thrown your way and with testing could even have a go at pcb design, basically whatever help.....just a thought.
Last edit: 16 Jan 2022 00:33 by ALittleOffTheRails.
  • scotta
  • Platinum Member
  • Platinum Member
19 Jan 2022 06:20 #232402 by scotta
Ethernet communication using the Remora data protocol with the Remora-eth LinuxCNC component is now working. No issues with a 1kHz servo thread frequency.
The following user(s) said Thank You: arvidb, tommylight, Pro_El, FCS Industrial, pinder, tuzki, AlessandroEmm, ALittleOffTheRails
Time to create page: 2.913 seconds
