  • scotta
  • Platinum Member
  • Platinum Member
26 Oct 2022 01:53 #255071 by scotta
I don't believe the YouTube videos showing how easy it is to remove BGA chips! The RT1052 is removed from the board but unfortunately the board will now be sacrificial  and a couple of the pads and tracks didn't survive. Still useful for reverse engineering the circuit.
  • scotta
  • Platinum Member
  • Platinum Member
26 Oct 2022 01:58 - 26 Oct 2022 01:59 #255072 by scotta
Would people be interested / willing to donate a few dollars to purchase sacrificial controller boards? I'm up for a new EC300 to test software on and I cannot now bring myself to remove the chip from the NVEM board I've been loaned.
Last edit: 26 Oct 2022 01:59 by scotta.
26 Oct 2022 16:46 #255110 by kwarup
Yes how to do it ?
26 Oct 2022 16:47 #255111 by kwarup
Yes, how can i send you $$ ?
26 Oct 2022 18:26 - 26 Oct 2022 18:29 #255118 by RogEnk
Of course!
More than happy too, would also donate to buy you a drink to be honest
Last edit: 26 Oct 2022 18:29 by RogEnk.
26 Oct 2022 19:58 #255127 by Snap1202
Sure let us know how we can best support you
  • scotta
  • Platinum Member
  • Platinum Member
27 Oct 2022 06:09 #255163 by scotta
Thanks for the support! I've set up a gofundme page.
www.gofundme.com/f/remora-firmware-devel...gn=p_cf+share-flow-1
27 Oct 2022 18:06 #255218 by RogEnk
Done!
The following user(s) said Thank You: tommylight, MX_Master, scotta
27 Oct 2022 20:40 #255239 by Aaroncnc
Done.
good luck.
The following user(s) said Thank You: tommylight, MX_Master, RogEnk
  • scotta
  • Platinum Member
  • Platinum Member
28 Oct 2022 19:39 #255327 by scotta
Thanks to those who've donated. Everything little bit helps with the wife :-)
With the EC300 out of action, I took the plunge with the loaned NVEM board. I took a copy of the firmware and did a compare with the EC300 firmware. They are a byte for byte match!
If the firmware is the same is the underlying circuit for these boards the same as well...I hope so!
The following user(s) said Thank You: MX_Master
Time to create page: 0.623 seconds
