- nighteagle
- Thank you received: 8
27 Apr 2026 11:44 #345975
by nighteagle
Replied by nighteagle on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello,
have found out the Problem - have flashed another bin gain - now 4 different Versions in the same project.
Have edit the above Post for others looking a way to bring this thing to work.
- jean
05 May 2026 20:17 #346184
by jean
Replied by jean on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello, good afternoon. Could someone help me load the .bin firmware onto the EC500 RT1052? I've tried several programs and commands, but without success. I have the Chinese Stlink V2 and a Raspberry Pi Pico.
- RJB510
12 Jun 2026 09:09 #347041
by RJB510
Replied by RJB510 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Are you still stuck? I have some python scripts to load the firmware onto the board using Windows and powershell. Sometimes you need to power cycle the board a few times to validate that it connects.
- RJB510
12 Jun 2026 09:14 - 14 Jun 2026 00:24 #347042
by RJB510
Hey everyone,
Has anyone been successful in configuring an XYYZ setup and would be happy to share their .ini and .hal files, and possibly the EC500 JSON config file (if modified)?
I've reviewed the suggested example files and mine seem to be correct for a dual Y axis motor gantry, but it's not working correctly and I'm chasing my tail trying to figure it out, so time to ask for some help! If possible!
Edit: All good, i got it working with a fair bit of trial and error.
Last edit: 14 Jun 2026 00:24 by RJB510.
- tuxcnc
- Thank you received: 55
21 Jun 2026 08:03 #347181
by tuxcnc
Replied by tuxcnc on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
In EC500 controller I have burned one output (XD+ or XD-) and can not drive one axis motor.
Which IC must I replace?
- tuxcnc
21 Jun 2026 08:31 #347182
by tuxcnc
Fortunatelly this is possibility to bring it back to life.
I have developed the following procedure:
1. Disconnect the controller from the power supply.
2. Disconnect the programmer.
3. Short by jumper the BOOT_M0 pin with 3V3 (programming connector).
4. Turn on the 24V power supply and do not turn it off until the end.
5. Remove the jumper.
6 Connect the programmer (I use ST-Link, but others also work).
7. Run the script below:8. If it doesn't work, keep trying until you succeed.
The EC500 does not like programming and I have bricked two controllers some time ago.Hello, good afternoon. Could someone help me load the .bin firmware onto the EC500 RT1052? I've tried several programs and commands, but without success. I have the Chinese Stlink V2 and a Raspberry Pi Pico.
#!/bin/bash
pyocd reset --target mimxrt1050_quadspi
pyocd erase --chip --target mimxrt1050_quadspi
pyocd flash remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi
The following user(s) said Thank You: Murphy
- CNC_Manni
- Thank you received: 3
06 Aug 2026 18:12 #348502
by CNC_Manni
Replied by CNC_Manni on topic NVEM V5 RT1052
Hallo zusammen, könnt ihr mir bei folgendem Problem helfen?
Board: NVEM V5 (i.MX RT1052)
Getestete Firmware-Versionen: remora-rt1052-NVEM-0.2.1.bin, remora-rt1052-0.0.1.bin, remora-rt1052.bin — alle zeigen identisches Verhalten
Ping auf 10.10.10.10 funktioniert einwandfrei
upload_config.py sendet korrekt eine WRQ-Anfrage auf Port 69 (bestätigt per tcpdump), erhält aber nie eine Antwort vom Board
Keine Firewall aktiv (iptables ACCEPT), direkte Verbindung ohne Router
Gibt es eine spezielle Prozedur, um den TFTP-Config-Upload auf diesem Board zu aktivieren (Pin kurzschließen, erst einen Befehl senden, o. ä.)?
Vielen Dank schon mal im Voraus!
- CNC_Manni
07 Aug 2026 12:58 #348528
by CNC_Manni
Replied by CNC_Manni on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I'm running into an issue and hoping you might have found a solution since posting this.
I'm using an NVEM V5 board (RT1052 chip). I successfully flashed the firmware via pyOCD
(tried multiple firmware versions: remora-rt1052-NVEM-0.2.1.bin, remora-rt1052-0.0.1.bin,
remora-rt1052.bin - all flashed without errors). Ping to 10.10.10.10 works perfectly and consistently.
However, unlike your case, I'm getting a timeout on my very first config upload attempt -
not after a successful first upload.
I've tried:
- My own custom config file
- The unmodified official example configs (both nvem-rt1052.txt and remora-rt1052-basic/ec500-rt1052.txt)
- Uploading with the SWD/ST-Link connection both attached and disconnected during the upload
- Confirmed via tcpdump that the WRQ packet is sent correctly on port 69, but no response ever comes back from the board
- No firewall involved (iptables set to ACCEPT), direct point-to-point Ethernet connection, no router
The script always confirms "Valid JSON config file" and calculates the CRC correctly,
so it gets stuck at exactly the same point you describe - after everything on the PC side looks fine.
Did you ever find out what caused the board to stop responding to TFTP?
Was it possibly related to the eStop/enable state getting stuck, as you mentioned the LED stayed
permanently lit? Any insight into how you (or anyone else) resolved this would be hugely appreciated -
trying to avoid unnecessary re-flashing if there's a known cause.
Additional update: I ran a UDP port scan to check the TFTP service status directly:
sudo nmap -sU -p 69 10.10.10.10
Result:
PORT STATE SERVICE
69/udp closed tftp
This is significant - "closed" (not "open|filtered", which is the typical ambiguous UDP result)
means the board actively responds with an ICMP port-unreachable message. This confirms the
TFTP service itself is never bound/listening on port 69 at all - it's not just that requests go
unanswered on an otherwise-open port.
I also looked through remora-rt1052.cpp and noticed the TFTP server is initialized via:
IAP_tftpd_init(dmaThread->DMAptr->EDMA_Handle);
in the ST_SETUP state, right after loadModules(). This suggests the TFTP server initialization
may never complete successfully during startup - which would explain why port 69 shows as actively
closed rather than just non-responsive.
I've now tested every available NVEM-specific firmware (only remora-rt1052-NVEM-0.2.1.bin exists
in the Remora-RT1052 repo) as well as the generic 3.1.x versions from Remora-RT1052-cpp
(which don't even respond to ping on this NVEM V5 board, matching what "disneysw" reported earlier
in this thread). I'm at the limit of what I can diagnose from the outside - any insight into the
TFTP server startup sequence would be much appreciated.
Thanks in advance!
I've tried:
Result:
PORT STATE SERVICE
69/udp closed tftp
Thanks in advance!
- ckaza13
23 Aug 2026 15:23 #348937
by ckaza13
Replied by ckaza13 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
TANDEM Y AXIS CLOSED LOOP STEPPER MOTOR OSCILLATION WHEN IDLE
Hello all,
threre is a stepper motor ticking issue going in my cnc mill that has been bothering me for a while now. I have devoted a fair amount of effort trying to "trial and error" my way out of it by playing around with tuning parameters but i cant reach a satisfactory solution, so hopefully someone here can provide some much needed assistance or reference to a similar case if the topic has already been covered before.
CONTROL SETUP DESCRIPTION
In my setup i use a rpi4b as the linuxcnc host along with an EC300 bob in which i have flashed the 3.1.3 version of the remora firmware for the RT1052 processor. Rpi and EC300 exchange packets over ethernet. 4 integrated closed loop stepper motors are driven by the the EC300 board using the corresponding STEP/DIR pins. Feedback from the motor's encoder does not reach linuxcnc so it essentially acts an an open loop system.
INITIAL ISSUE DESCRIPTION
In the capture5.txt i have recorded the following signals of J1 (one of the two joints driving the Y axis, the other is J3) in the servo_thread period while the joint reached the idle state after executing a jog command in my initial attempts to get my machine going.
1st column : j1pos-cmd
2nd column : j1pos-fb
3rd column : j1freq-cmd
at the time of the recording J1 was configured this way (scale and the rest of the dynamic parameters remained the same to my current configuration) :
CURRENT STATUS
In the attached .ini, .hal , remora-config-file.txt you can see how my machine is currently configured. Apparently by not specifying a p_gain and ff1_gain they both default to 1 according to the remora-eth-3.0.c and with a deadband of 0.005 the Y axis is able to reach a steady state. The reason i am not satisfied is because the motion isn't smooth when approaching the final position, instead the motors "click" in place after a few steps and the axis makes a squeeking noise. When i try to modify the gain parameters to smooth the axis i roll back to the initial issue of not being able to reach a steady state.
Probably i did a poor job explaining the chronicle of my situation but hopefully i ll be able to further clarify in follow up questions.
Thank you
Hello all,
- remora.joint.1.pgain = 5
- remora.joint.1.ff1gain = 1
- remora.joint.1.deadband = 0.02
CURRENT STATUS
Thank you
- Murphy
05 Oct 2026 17:50 - 06 Oct 2026 05:46 #350138
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Has anybody got G95 working with their remora setups??
iv got it working by setting lowpass-spindle-encoder-velocity.gain to true.
But how do I permanently set it to true. I tried setp in .Hal but it's getting overwritten every time I restart linuxcnc
Last edit: 06 Oct 2026 05:46 by Murphy.
Time to create page: 0.302 seconds
