30 Jul 2025 19:12 #332570 by Murphy
It's in the image you downloaded. Look for the components folder I think it was called. Open that, you should see the Eth files. Open the terminal(command line) from here and run the halcomplie command that's in step 8 of the instructions.
01 Aug 2025 14:55 #332628 by Mars
Replied by Mars on topic Remora - Can it host analog inputs?
Scott. Please forgive me if I am using the forum improperly. I have a project that I would like to base on RPI5 and Remora on a Bigtreetech board. I have read all the Remora documentation and studied all the config.txt files in your github. The question: can Remora support a general analog input (say to an ADC pin on the supporting processor)? In the limit, can I repurpose one of the thermistor inputs or are they dedicated to thermistor processing? TIA.
01 Aug 2025 15:33 #332629 by Mars
Replied by Mars on topic Remora - Does Analog input syntax exist?
I have poured over the Remora documentation but can't find the syntax (if it exists?) for the config.txt to set up an input on a Remora supported controller board as an analog input. Is there a way? I have gone over all the config.txt files that I can find and they all seem to be variants of 3d printers and they have thermistor specific inputs (which are analog I realize but the only general signal inputs seem to be digital. Any help/hints/links other appreciated. TIA
  • scotta
  • Platinum Member
  • Platinum Member
01 Aug 2025 22:01 #332647 by scotta
Replied by scotta on topic Remora - Does Analog input syntax exist?
You're correct. In the currently available modules there is no basic analog input. But the underlying code is there and used in the thermistor module.
02 Aug 2025 04:36 #332658 by unknown
Replied by unknown on topic Remora - Does Analog input syntax exist?
Dear new Member please don't change the Subject when posting it renames the thread in the Index and makes it hard to find
02 Aug 2025 11:10 #332661 by Mars
Thanx and I sorry about changing subject line...didn't realize it created problems.
The following user(s) said Thank You: unknown
  • scotta
  • Platinum Member
  • Platinum Member
02 Aug 2025 20:46 #332696 by scotta
Replied by scotta on topic Remora - NVEM / EC300 / EC500
Post to change the title back to Remora - NVEM / EC300 / EC500.
03 Aug 2025 18:02 #332740 by michaelvdberghe
Replied by michaelvdberghe on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
hi guy's
i just finished flashing the firmware to my digital dream ec500v5 and upload the config file. now I'm i bit confused about proceeding and the documentation isn't making a whole lot a scene at the moment. I'm wondering do i need to make a hal file which contains the the pins from the ec500 and then let the main hal file call up the pin file?
I'm a total newby to this without any programming background. and the plan is to try and build a plasma table for my small buissnes.
thanks in advance
  • scotta
  • Platinum Member
  • Platinum Member
03 Aug 2025 20:09 #332759 by scotta
Use the example configuration as a starting point and then add your hal configuration for end stop etc as you need.
github.com/scottalford75/Remora-RT1052-c.../remora-rt1052-basic
06 Aug 2025 17:30 #332970 by michaelvdberghe
so i dont understand how these correspond to physical pins on the remora board itself, do you still have to add those manualy in the code.
# estop and SPI comms enable and feedback
net user-enable-out <= iocontrol.0.user-enable-out => remora.enable
net user-request-enable <= iocontrol.0.user-request-enable => remora.reset
net remora-status <= remora.status => iocontrol.0.emc-enable-in
espacialy for the x-axis i dont see where the enable pin is or where the xp+, xp-, xd+,xd- are refferencd in the code here. i realy dot get it, the documentaion is not making sence.
# joint 0 setup (X axis)
setp remora.joint.0.scale [JOINT_0]SCALE
setp remora.joint.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net j0pos-cmd joint.0.motor-pos-cmd => remora.joint.0.pos-cmd
net j0pos-fb remora.joint.0.pos-fb => joint.0.motor-pos-fb
net j0enable joint.0.amp-enable-out => remora.joint.0.enable
Time to create page: 1.123 seconds
