- Thank you received: 489
With the DMA stepgen implementation you do not have the flexibility to change the PRU_base_freq on the controller board. It is hard coded for 500khz. In LinuxCNC the command line setting only sets the upper frequency limit (velocity command) allowed to be sent to the controller board.Hi there
To recap, I am trying to setup LinuxCNC with the testing branch of DMA (IE the cpp firmware)
I have formatted a new computer with Debain 12 (Bookworm) as the old computer I was using had had a lot of different softwares during the course of testing various things.
I am running "LINUXCNC - 2.9.0~pre1+git20230208.f1270d6ed7"
And I have put loadrt remora-nv PRU_base_freq=450000 in my HAL file (also changed the remora-nv.c to 500000 )
I have changed the PRU from 80000 to 450000 in stages, but the problem remains.
The problem is this, sometimes when I start LinuxCNC everything runs smoothly & other time when I jog the axis they stutter & stall. I haven't changed anything. When I exit & restart it sometimes fixes itself. There doesn't seem to be any rime or reason.
I know this is all experimental but I thought I'd see if anyone else had come across this.
I have a video of whats happening so see what you think.
Just to repeat the PRU value doesn't change between videos.
youtube.com/shorts/XIrLCH1m3ZI?feature=share
Alex
Yeah, some organization wouldn't hurt. I'm very greatful for the hard work by people like Scott, but for a beginner like me, it can be quite difficult when the documentation and organization isn't complete.If voltage is not an issue, I suggest use AC probably. something like 200W-400W is what your size group will be.
Which one is the correct one to use for NVEM with STM32F207?
Yeah good question. Everything is rather confusing at the moment. A newly structured Remora repo is in the works with all firmware, configs and components in one central location, to make everything much easier.
According to the docs , NVEM is the branch you are looking for, as stated before
remora-docs.readthedocs.io/en/latest/har...hernet/ethernet.html
