- Thank you received: 12
From what I could observe and this is just my experience, the directional changes happen only between restarts of linuxcnc . And in my case it happened only for one of the motors of the tandem y axis where one of the motors will start to spin ccw when they should both spin cw. This occurs withbought power cycling the board. For me, the directional switch never happened during the same session of linuxcnc.
I'm very very suspicious that these random cases are due to how the DR_TOGGLE register is being used and in some cases the output pattern become inverted. The DR_TOGGLE register needs less computation to fill but if the reliability is not there then I'd rather move to using the DR register and spend more CPU time to generate the full step pattern, not just the step change locations. Most people are unlikely to have 6 axes running at 500khz at any one time so we'll still have enough CPU time to do the step buffer fill.
I have the 5v turret tool position signal on input 3 and index on input 4.
Input 1 and 2 are the 24v Prox sensor. Pulses every stepper rotation. For homing. Works perfect.
When driving the turret you can see the LEDs lighting on the optocoupler and on the EC500 but they are a lot dimmer than input 1 and 2. The inputs for the turret are not registering in hal. Am I right in thinking the 5v input isn't enough to drive the optocouplers? Even it says it will work with 3.3v and 5v.
