- Thank you received: 5
Some good news. I've found what's broken the NVMPG... just need to figure out how to fix it. The DMA stepgen implementation is the issue with most likely a channel conflict or something happening..... head scratching time.Hi all, hi scotta,
I still have a problem with my NVMPG, like in forum.linuxcnc.org/18-computer/44828-rem...rd?start=1710#298883 already stated. I have the same behaviour.
I can control the axis with the NVMPG, switch the axis and scales, but I don't see anything useful on the NVMPG.
Did someone succeed in making the display work?
I use a EC500 with the firmware Remora-RT1052-cpp version 3.1.2.
Regards, hanskuster
