2 years 3 months ago #306152 by scotta
Channel conflict was the issue. Bug fix release now available in the repo. Tested with standard stepgen and DMA stepgen with NVMPG.
github.com/scottalford75/Remora-RT1052-c...ora-rt1052-3.1.3.bin
Please share any issues. Thanks
The following user(s) said Thank You: oneohm, hanskuster
2 years 3 months ago #306173 by cncmiljc
One question, I'm studying the Remora-EC500-DMAstepgen, but I don't have any signal of pulses, could you tell me if in your tests, you were able to pulse the motors with DMA and this configuration? If so, could you tell me why this configuration is not happening? github.com/scottalford75/Remora-EC500-DMAstepgen
2 years 3 months ago #306181 by hanskuster
Hi all, hi scotta,
I reflashed my EC500 with the newest firmware to check if the NVMPG now works.
After reflashing LinuxCNC doesn't connect anymore. The EC500 doesn't respond to pings either.
I wanted to erase the EC500 to reflash it from new, but erase doesn't work anymore.
Issuing this command:
pyocd erase --target mimxrt1050_quadspi --mass
returns this error message:
0000718 C No ACK received [__main__]
I use a DAP Link btw.
I flashed the newest firmware to a second EC500, and now this one seems to bricked also.
I can't erase nor re-flash both of them anymore.
How can I un-brick them?
regards, hanskuster
2 years 3 months ago - 2 years 3 months ago #306185 by Lpkkk
How to fix timeout error during uploading config for nvem board?
Ping 10.10.10.10 went OK
Last edit: 2 years 3 months ago by Lpkkk.
2 years 3 months ago #306198 by scotta
That repo is only for sharing of development work done on the STM32 for a DMA stepgen. The algorithm and DMA works but the STM32 was not fast enough to generate the step patterns. The only working DMA stepgen in for the RT1052 based boards.
2 years 3 months ago #306209 by scotta
Hi all, hi scotta,
regards, hanskuster
I'd resort back to MCUXpresso. When I've had trouble with bad firmware / flashing I've been able to recover the board by powering on while the probe is trying to connect.
The following user(s) said Thank You: hanskuster
Time to create page: 0.639 seconds
