- Thank you received: 5
sorry to bother you all, but I'm trying to set up remora on my NVEM V2. I was able to flash the firmware and upload the config file. LinuxCNC seems to be able to talk to the board (there is a lot of network traffic between the two); however, I'm having troubles with the inputs (I'm trying the e-stop, but it's the same with the others): when I flip the e-stop button the state of the input pin changes (the voltage drops to 0V as I'm using an NC button) but remora does not "see" it, the input pin in the HAL configuration stays low in any case.
Do you have any suggestions of what could be causing this? May I have flashed the wrong firmware/incorrectly?
I have to say I haven't tried sending some gcode yet, I wanted to have the safeties active before anything else.
Best regards,
Alberto M.
