Remora - NVEM / EC300 / EC500
- scotta
- Thank you received: 480
18 Sep 2024 20:40 #310413
by scotta
Hi, unfortunately no. The QEI is for the STM32 based boards, the QDC for the RT1052. These refer to the decoding circuits integrated into the MCUs. The QDC has the capability to count a single channel, but the current software implementation cannot take advantage it.
- Murphy
- Thank you received: 5
18 Sep 2024 20:53 #310415
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
How hard is it to get the single A pulse and Z index working for the spindle? Is it going to be future update ?
- cakeslob
- Thank you received: 275
18 Sep 2024 23:09 #310419
by cakeslob
for user xaxexa, when you say one pulse output , are you referring to it as only an A channel (x pulse/revolution) or do you mean it is a single pulse like an index channel where 1 pulse/revolution ?
if it is the index channel, you could probably implement it.
Echo to Murphy, we could benefit from having the option for only A/Z as it seems common for lathe users, , Myself and other users are finding increasing need for a non quadratic option so the encoder module can be used for MPG. Using Encoder module vs DIgitial IO for an MPG is a cleaner hal file, but also using digital IO for MPG uses 12% of the available inputs on the SPI version
The following user(s) said Thank You: Murphy
- xaxexa
20 Sep 2024 03:06 #310486
by xaxexa
Replied by xaxexa on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
look, the square encoder gives us the direction and frequency, you can also calculate the angle and so on, depending on the accuracy of the encoder, the Z channel allows you to refer to the position of something, for the MPG Z is not needed, for stepper motor feedback, I would choose a diver with encoder support, and now I want feedback of the spindle speed, in theory it can be implemented using A encoder channel, or the Z channel theoretically could also give such functionality, I don’t need to cut threads, just feedback of revolutions per minute
- xaxexa
20 Sep 2024 14:31 #310517
by xaxexa
Today I was sitting with a frequency generator
my notes, if you enter only channel A in txt, the counter counts 0,1,0,1,0,1 instead of 0,1,2,3,4,5, there is no acceleration, and velocity = 0
if you connect A and B to the same pin, then at a low frequency the counter is 0, apparently the board understands that the pulse comes at the same time, if you increase the frequency above 1 kHz, errors begin, and the counter begins to increase or decrease non-linearly, well, it seems the simplest thing is to exclude channel B from the calculation, but I don't have the knowledge at all to write such a commit...
and I also need to use the PRU encoder module, not just an encoder, right?
- aDm1N
29 Sep 2024 19:32 #311041
by aDm1N
Replied by aDm1N on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
The fact that I couldn't flash the board is because it is defective for whatever reason. Is on the way back now. Now I'm wondering what happens next. Of course, getting a new NVEM would work. or would an EC300 or EC500 be a better choice? A standard MPG should be connected with individual cables, so an NVEM is probably easier at first. Mesa cards are hard to come by right now, or much more expensive. If you were faced with a choice right now, what would your decision be?
- xaxexa
02 Oct 2024 15:22 - 02 Oct 2024 15:24 #311181
by xaxexa
help me figure it out, I'm still trying to make a frequency counter on one wire, with a QDC module, I found a solution, now in the variable pv0 I see a growing counter, with an adequate frequency exactly the same as on the frequency generator, I took the Linux module "counter", removed everything unnecessary from it, connected pv0 with raw_counts I see the value velocity, but it is with an accuracy of 1 kilohertz, how to reduce it to 1 hertz??? is this related to the servo thread refresh rate?
#include "rtapi.h" /* RTAPI realtime OS API */
#include "rtapi_app.h" /* RTAPI realtime module decls */
#include "rtapi_errno.h" /* EINVAL etc */
#include "hal.h" /* HAL public API decls */
#define MODNAME "PRUcounter"
/* module information */
MODULE_AUTHOR("Chris Radek");
MODULE_DESCRIPTION("Pulse Counter for EMC HAL");
MODULE_LICENSE("GPL");
static int num_chan = 1; /* number of channels - default = 1 */
RTAPI_MP_INT(num_chan, "number of channels");
* STRUCTURES AND GLOBAL VARIABLES *
/* this structure contains the runtime data for a single counter */
typedef struct {
hal_float_t *raw_count; /* pin: raw binary count value */
hal_float_t *vel; /* scaled velocity (floating point) */
hal_float_t *pos_scale; /* pin: scaling factor for pos */
double old_scale; /* stored scale value */
double scale; /* reciprocal value used for scaling */
hal_s32_t last_count;
} counter_t;
/* pointer to array of counter_t structs in shmem, 1 per counter */
static counter_t *counter_array;
/* other globals */
static int comp_id; /* component ID */
* LOCAL FUNCTION DECLARATIONS *
static int export_counter(int num, counter_t * addr);
static void update(void *arg, long period);
static void capture(void *arg, long period);
* INIT AND EXIT CODE *
#define MAX_CHAN 8
int rtapi_app_main(void)
int n, retval;
/* test for number of channels */
if ((num_chan <= 0) || (num_chan > MAX_CHAN)) {
rtapi_print_msg(RTAPI_MSG_ERR,
"COUNTER: ERROR: invalid num_chan: %d\n", num_chan);
return -EINVAL;
/* have good config info, connect to the HAL */
comp_id = hal_init("PRUcounter");
if (comp_id < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "COUNTER: ERROR: hal_init() failed\n");
return -EINVAL;
/* allocate shared memory for counter data */
counter_array = hal_malloc(num_chan * sizeof(counter_t));
if (!counter_array) {
"COUNTER: ERROR: hal_malloc() failed\n");
hal_exit(comp_id);
return -ENOMEM;
/* export all the variables for each counter */
for (n = 0; n < num_chan; n++) {
/* export all vars */
retval = export_counter(n, &;(counter_array[n]));
if (retval != 0) {
"COUNTER: ERROR: counter %d var export failed\n", n);
hal_exit(comp_id);
return -EIO;
/* init counter */
*(counter_array[n].raw_count) = 0;
*(counter_array[n].pos_scale) = 1.0;
counter_array[n].old_scale = 1.0;
counter_array[n].scale = 1.0;
/* export functions */
retval = hal_export_funct("PRUcounter.update-counters", update,
counter_array, 0, 0, comp_id);
if (retval != 0) {
"COUNTER: ERROR: count funct export failed\n");
hal_exit(comp_id);
return -EIO;
retval = hal_export_funct("PRUcounter.capture-position", capture,
counter_array, 1, 0, comp_id);
if (retval != 0) {
"COUNTER: ERROR: capture funct export failed\n");
hal_exit(comp_id);
return -EIO;
rtapi_print_msg(RTAPI_MSG_INFO,
"COUNTER: installed %d counter counters\n", num_chan);
hal_ready(comp_id);
return 0;
void rtapi_app_exit(void)
hal_exit(comp_id);
* REALTIME COUNTER COUNTING AND UPDATE FUNCTIONS *
counter_t *cntr;
int n;
for (cntr = arg, n = 0; n < num_chan; cntr++, n++) {
// count on rising edge
(*cntr->raw_count)++;
counter_t *cntr;
int n;
/* check reset input */
int raw_count;
int counts;
/* capture raw counts to latches */
raw_count = *(cntr->raw_count);
counts = (raw_count - cntr->last_count);
cntr->last_count = raw_count;
/* check for change in scale value */
if ( *(cntr->pos_scale) != cntr->old_scale ) {
/* save new scale to detect future changes */
cntr->old_scale = *(cntr->pos_scale);
/* scale value has changed, test and update it */
if ((*(cntr->pos_scale) < 1e-20) && (*(cntr->pos_scale) > -1e-20)) {
/* value too small, divide by zero is a bad thing */
*(cntr->pos_scale) = 1.0;
/* we actually want the reciprocal */
cntr->scale = 1.0 / *(cntr->pos_scale);
/* scale counts to make floating point velocity */
*(cntr->vel) = counts * cntr->scale * 1e9 / period;
* LOCAL FUNCTION DEFINITIONS *
int retval, msg;
/* This function exports a lot of stuff, which results in a lot of
logging if msg_level is at INFO or ALL. So we save the current value
of msg_level and restore it later. If you actually need to log this
function's actions, change the second line below */
msg = rtapi_get_msg_level();
rtapi_set_msg_level(RTAPI_MSG_WARN);
/* export parameter for raw counts */
retval = hal_pin_float_newf(HAL_IN, &;(addr->raw_count), comp_id,"counter.%d.raw_count", num);
if (retval != 0) {
return retval;
/* export pin for scaled velocity captured by capture() */
retval = hal_pin_float_newf(HAL_OUT, &;(addr->vel), comp_id, "counter.%d.velocity", num);
if (retval != 0) {
return retval;
/* export parameter for scaling */
retval = hal_pin_float_newf(HAL_IO, &;(addr->pos_scale), comp_id, "counter.%d.position-scale", num);
if (retval != 0) {
return retval;
/* restore saved message level */
rtapi_set_msg_level(msg);
return 0;
Warning: Spoiler!
typedef struct {
} counter_t;
/* other globals */
#define MAX_CHAN 8
int n, retval;
return -EINVAL;
if (comp_id < 0) {
return -EINVAL;
hal_exit(comp_id);
return -ENOMEM;
if (retval != 0) {
hal_exit(comp_id);
return -EIO;
/* init counter */
if (retval != 0) {
hal_exit(comp_id);
return -EIO;
if (retval != 0) {
hal_exit(comp_id);
return -EIO;
hal_ready(comp_id);
return 0;
hal_exit(comp_id);
counter_t *cntr;
int n;
counter_t *cntr;
int n;
int raw_count;
int counts;
int retval, msg;
if (retval != 0) {
return retval;
if (retval != 0) {
return retval;
if (retval != 0) {
return retval;
return 0;
Last edit: 02 Oct 2024 15:24 by xaxexa.
- xaxexa
02 Oct 2024 16:10 #311187
by xaxexa
figured it out, yes it is connected with the servo thread speed... I will continue to do it...
- xaxexa
07 Oct 2024 08:50 #311475
by xaxexa
Check github pls
remora cpp
- aDm1N
08 Oct 2024 21:04 #311611
by aDm1N
So, the new board has arrived (NVEM). Soldered the cable and tried it quickly with Windows. It worked and I get an answer from 10.10.10.10
Now let's move on.
Now let's move on.
C:\Users\adm1n\Nextcloud\LinuxCNC_Minidrehbank\Remora-RT1052-cpp\Firmware>pyocd list
# Probe/Board Unique ID Target
0 ARM DAPLink CMSIS-DAP 070000811a5a5bb50000000001ef41eca5a5a5a597969908 ✔︎ stm32f103rb
NUCLEO-F103RB
C:\Users\adm1n\Nextcloud\LinuxCNC_Minidrehbank\Remora-RT1052-cpp\Firmware>pyocd flash remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi -v
0005355 W STLink, CMSIS-DAPv2 and PicoProbe probes are not supported because no libusb library was found. [common]
0007141 I Target type is mimxrt1050_quadspi [board]
0007232 I DP IDR = 0x0bd11477 (v1 MINDP rev0) [dap]
0007310 I AHB-AP#0 IDR = 0x04770041 (AHB-AP var4 rev0) [discovery]
0007357 I AHB-AP#0 Class 0x1 ROM table #0 @ 0xe00fd000 (designer=00e:NXP part=88c) [rom_table]
0007373 I [0]<e00fe000:ROM class=1 designer=43b:Arm part=4c8> [rom_table]
0007373 I AHB-AP#0 Class 0x1 ROM table #1 @ 0xe00fe000 (designer=43b:Arm part=4c8) [rom_table]
0007404 I [0]<e00ff000:ROM class=1 designer=43b:Arm part=4c7> [rom_table]
0007404 I AHB-AP#0 Class 0x1 ROM table #2 @ 0xe00ff000 (designer=43b:Arm part=4c7) [rom_table]
0007433 I [0]<e000e000:SCS v7-M class=14 designer=43b:Arm part=00c> [rom_table]
0007436 I [1]<e0001000:DWT v7-M class=14 designer=43b:Arm part=002> [rom_table]
0007436 I [2]<e0002000:FPB v7-M class=14 designer=43b:Arm part=00e> [rom_table]
0007452 I [3]<e0000000:ITM v7-M class=14 designer=43b:Arm part=001> [rom_table]
0007468 I [1]<e0041000:ETM M7 class=9 designer=43b:Arm part=975 devtype=13 archid=4a13 devid=0:0:0> [rom_table]
0007484 I [2]<e0042000:CTI CS-400 class=9 designer=43b:Arm part=906 devtype=14 archid=0000 devid=40800:0:0>
[rom_table]
0007499 I [1]<e0040000:TPIU M7 class=9 designer=43b:Arm part=9a9 devtype=11 archid=0000 devid=ca1:0:0> [rom_table]
0007499 I [2]<e0043000:TSGEN class=15 designer=43b:Arm part=101> [rom_table]
0007515 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0007531 I CPU core #0: Cortex-M7 r1p1, v7.0-M architecture [cortex_m]
0007547 I Extensions: [DSP, FPU, FPU_DP, FPU_V5, MPU] [cortex_m]
0007547 I FPU present: FPv5-D16-M [cortex_m]
0007574 I 4 hardware watchpoints [dwt]
0007579 I 8 hardware breakpoints, 1 literal comparators [fpb]
0007642 I Loading C:\Users\adm1n\Nextcloud\LinuxCNC_Minidrehbank\Remora-RT1052-cpp\Firmware\remora-rt1052-3.1.3.bin [load_cmd]
0007816 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0007831 I IMXRT Boot Device: 0 [target_imxrt]
[==================================================] 100%
0083752 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0083763 I IMXRT Boot Device: 0 [target_imxrt]
0083889 I Erased 393216 bytes (6 sectors), programmed 358656 bytes (1401 pages), skipped 0 bytes (0 pages) at 4.60 kB/s [loader]
Time to create page: 0.236 seconds
