Bluetooth RS232
- rfhowell68
06 Oct 2010 22:36 #4543
by rfhowell68
Bluetooth RS232 was created by rfhowell68
I dont have a 25 pin connector on my pc. Has anyone tried Bluetooth RS232 to talk to there cnc controller?
- BigJohnT
- Thank you received: 1176
06 Oct 2010 22:59 - 06 Oct 2010 23:00 #4545
by BigJohnT
Replied by BigJohnT on topic Re:Bluetooth RS232
I'm sure the transmission rate is too slow for real time applications like CNC.
If you don't have a parallel port you will have to use a pci card. If your trying to use a laptop save yourself loads of time and don't.
Last edit: 06 Oct 2010 23:00 by BigJohnT.
- rfhowell68
06 Oct 2010 23:14 - 07 Oct 2010 00:18 #4546
by rfhowell68
Replied by rfhowell68 on topic Re:Bluetooth RS232
230k max is the rate for my bluethooth RS232 . I have done DNC on machines at much slower rate, althouth this was just a program being feed to the machine, and not fully controlling it.
Just took a look as some serial port card. Most had a 460K max rating and I did find a bluetooth RS232 that also supports 460K.
Last edit: 07 Oct 2010 00:18 by rfhowell68.
Time to create page: 0.218 seconds
