I've looked at two breakout boards for the RPi 4, the Mesa 7c81 and the 7i76e. I see there are a huge difference in price, where the 7c81 is 90$ and the 7i76e is 200$. The 7c81 also have a much smaller form factor as it integrate with the RPi4.
So my question as a noob in this area, what board will be the easiest for me to set up and work with my accessories/drivers, and are there any known good step by step tutorials for this or any special threads in here I should read for that matter?
Did you make a decision on which Mesa board you're going to use ?
Looks like the main difference between the two is that the 7c81 requires additional breakout boards connected via the three 26 pin ports in order to connect anything to it.
The 7i76 has the connections built-in on the board.
