Full screen
19 Oct 2022 10:55 - 20 Oct 2022 14:56 #254506 by xlordofpainx
I am trying to get full screen using Virtual box and the iso image.
I tried ctrl+ f  and I get nothing *attachment fullscreen1.
Tried Virtual Box options: *attachment fullscreen2. - same small window. I searched the Forum but didn't find anything on full screen.
Normally it's quite easy, but I can't get a full screen on Linux CNC.
SOLVED by installing VB guest additions - many tutorials on the internet on this.
Last edit: 20 Oct 2022 14:56 by xlordofpainx.
19 Oct 2022 13:11 #254520 by tommylight
Replied by tommylight on topic Full screen
Moved to "computers and OS's".
LinuxCNC is software that runs on Linux.
You started 2 new topics about issues with virtual box.
Search the web for Debian and virtual box as LinuxCNC official ISO uses Debian Linux.
Debian is the operating system you have issues with, not LinuxCNC.
19 Oct 2022 18:16 #254549 by HansU
Replied by HansU on topic Full screen
The login screen is usually at a lower resolution than the system when logged in.
Is it the resolution the same when you logged in? Then you might change the resolution in the Debian settings or install the Virtual Box Guest Additons...
20 Oct 2022 14:52 #254602 by xlordofpainx
Replied by xlordofpainx on topic Full screen
Hey thanks a lot
Hey. We fixed it. I installed guest additions VB. Now In my case I was not able to resize, but all else worked.
Here is a list of all tutorials on the topic. It was kinda hard getting the guest additions to work on the Debian Linux CNC iso in Virtual box. but did it.
20 Oct 2022 16:52 #254617 by snowgoer540
Replied by snowgoer540 on topic Full screen
You need to install the kernel headers, and then reinstall the guest additions.  Then resizing the resolution, etc will work.
20 Oct 2022 19:46 #254627 by xlordofpainx
I see. Great to know. Thank you.
23 Oct 2022 15:30 - 23 Oct 2022 15:31 #254859 by snowgoer540
Now that I am at my computer (and remembered), here is from my notes that I use when the updates inevitably break the resolution on my Virtual Machine (VirtualBox):
1. Install new kernel headers:
sudo apt install linux-headers-$(uname -r)
2. Insert the guest additions CD in VirtualBox (Devices --> Insert Guest Additions CD image...)
3. Navigate to:
media/<your_login_name>/<guest_additions_folder_thats_there>
4. Install the guest additions:
sudo ./VBoxLinuxAdditions.run
5. Restart
sudo shutdown -r now
After it restarts, you may have to do View --> Auto-resize Guest Display and then maximize should work.
Hope that helps.
Last edit: 23 Oct 2022 15:31 by snowgoer540.
Time to create page: 0.057 seconds
