Anyone using Odroid H3?
3 years 9 months ago #262653 by blazini36
Replied by blazini36 on topic Anyone using Odroid H3?
Manjaro just dropped a 6.0 rt kernel so I tried that which I was a bit hesitant to do because I had to update alot of packages. I typically don't update machines once they're setup....
And that killed it lol. Same problem I had when I setup the system from scratch. LinuxCNC will try to start  and get "USERMOT:Command Time out" errors all over the place. If I run latency-test it doesn't do anything, just starts with all the values staying at 0. I know this is due to some updated package, the only reason I got it to run in the first place is I used an image from a 4-month old setup on a similar PC. Any idea where to start to figure this out? No errors in dmesg or linuxCNC debug log other than the running terminal with the Usermot error.
I'm not a fan of Debian at all. Everytime I try to setup debian on this machine I abandon it because I need other outdated packages to run things besides LinuxCNC and they're gone from Debian and it's stuck in dependancy hell. Manjaro has everything on the AUR and up until now I could always get Manjaro running.
If I can't figure out what package broke LinuxCNC I may have to try Debian again anyway.
3 years 9 months ago #262678 by rodw
Replied by rodw on topic Anyone using Odroid H3?
Just download a CD iso for Debian Bookworm non-free and install it specifyong the XFCE desktop (mandatory)
That will give you the 6,x kernel
cdimage.debian.org/cdimage/unofficial/no...builds/amd64/iso-cd/
Then type
sudo apt install linuxcnc-uspace
sudo apt install linuxcnc-uspace-dev
And preempt_rt and linuxcnc will be installed by Debian magic!
I used to avoid Debian too but eventually found it was th eonly one that worked. Time to Surrender I think
3 years 9 months ago #262744 by blazini36
I don't think I realized LinuxCNC was packaged as debs yet, though I don't use anything Debian based much.
I'll give it a try, hopefully Debian actually has a working installer now.
3 years 9 months ago #262746 by blazini36
Looks like LinuxCNC has only been packaged for bookworm and it's 2.9.....I need 2.8.4, so looks like I'll be building it either way which I don't think will be easy for bookworm
3 years 9 months ago #262755 by rodw
If you use a 6.x kernel, you won't have any Python2 support so running Linuxcnc V 2.8 will be problematic on any platform
You need kernel version 5.9 and above to get support for your network card.
Linuxcnc 2.8 was built for kernel 4.9
You are between a rock and a hard place.
Debian Bullseye on kernel 5.10 is the first version of Debian that qualifies for your NIC.
There will be a number of hardware features that won't have full support on lower version of kernels.
You could use Bullseye but there ar no debs for it so you need to compile from source.
Bite the bullet and go to V 2.9 and leave all of the Python 2 incompatibilities behind. Bookworm is only a few months short of becoming the Debian release version.
Time to create page: 0.440 seconds
