Remora for RP2040
3 years 5 months ago #272315 by scotta
Replied by scotta on topic Remora for RP2040
I'm keen for this or something like this, just for GPIO even.
(E.g. for complementing an ethercat setup).
Watching with interest.
With step/dir even low step rates for additional things like auto tool changers would be quite helpful.
The current 40khz step rate is not too bad. I think we should be able to get it up to about 100kHz.
With the config file all of the pins could be configures as IO.
Below is the step and direction output, just to show it's actually working...
The following user(s) said Thank You: pippin88, besriworld
3 years 5 months ago #272321 by pippin88
Replied by pippin88 on topic Remora for RP2040
I'm not familiar with Remora - will it be possible to use multiple of these?
3 years 5 months ago #272323 by scotta
I'm not familiar with Remora - will it be possible to u,se multiple of these?
A good question and something that needs to be considered given the limited IO of a Pico. Currently the Remora Ethernet component has a fixed IP address it is looking to communicate to. If the LinuxCNC component is modified to accept a configurable IP address it would be possible to load multiple instances, in LinuxCNC, talking to different boards.
The controller board will also need to have a configurable IP address, a feature that has been requested for the NVEM, EC300 and EC500. This could be included in the uploaded config file (when I get it working), and a method to force a default config on boot to "reset" the board just in case we need to.
3 years 5 months ago #272329 by tommylight
The following user(s) said Thank You: scotta
3 years 5 months ago #272336 by Aaroncnc
Replied by Aaroncnc on topic Remora for RP2040
The 2040 is an interesting chip.
I hope it grows in popularity.
Do you think with the cores and the 4 state machines this could be faster than the current 3d printer variants?
3 years 5 months ago #272375 by scotta
Hi Aaron,
The port for the RP2040 is not utilising the PIO, so we will be limited like the 3d Printer boards.
Time to create page: 0.223 seconds
