Advice for choosing a compatible PC
3 years 1 month ago #279743 by Kosmas
Hi again.
While i was reading the "Hardware latency tests, used PC's" posts in forum, in page 10, there is a post (at 19 May 2021 17:32) by "TheFarfar" about an Asus P5B-MX, Intel Core2 Quad Q6600, 4 GB RAM.
Your comment was "That looks very good even for software stepping."
There is a PC exactly like this in Athens Greece (i am in Crete) at 50euros + 12Euros shipping cost.
I thing i have to bye it asap. It is ok for what i am going to do (XP-Mach3-USB card) and looks perfect for what i am "dreaming" to do (Linux-Mesa 7i96S)
What do you thing?
3 years 1 month ago #279745 by tommylight
Seems OK, but it is old and might have issues, caps can cause havoc as they dry out with time.
I still have an Asus P5B Deluxe with Intel Q9400, it still works but already shows issues, like not rebooting whet you tell it to and requiring a hard reset, or fails to boot and needs again a hard reset.
Try to find a Dell 980 or HP 8300 USDT, Dell tower also has parallel port so you can throw the "mach3 usb" :)
3 years 1 month ago #279752 by Kosmas
Thanks, thanks, thanks ......
3 years 1 month ago #279755 by Kosmas
Sorry when you say 980?
Dell Optiplex 980 MT i5-750/4GB/250GB/Quadro FX580
Dell Optiplex 980 SFF i5-650/4GB/250GB/DVD
Dell OptiPlex 980 DT Core i7-860 2,8 - SSD 128 Gb - 4GB
Dell Optiplex 980 MT i5 €55
CPU: Intel® Core™ i5-750 2.66GHz(8M)
Socket: LGA1156
Chipset: Intel Q57 Express chipset
Memory: 4GB DDR3
# of DIMMS: Two (2)
HDD: 250GB
ODD interface: DVD-RW SATA
Bays: (2) 5,25 External, 3.5 External, (2) 3.5 Internal
VGA: Nvidia Quadro FX580 512MB
RAID Controller: No
Front I/O: (4) USB 2.0, Audio I/O
Rear I/O: (6) USB 2.0, Audio I/O, RJ45, VGA, (2) PS2, DP, Serial
Slots: PCIe 2.0 x16, PCIe 2.0 x4
LAN: Gigabit 100/1000
Integrated Audio: HD audio (PC speaker)
Dell Optiplex 980 SFF i5 Intel® Core™ i5-650 3.20GHz (4M) €55
CPU: Intel® Core™ i5-650 3.20GHz (4M)
Socket: LGA1156
Memory: 4GB DDR3
# of DIMMS: Four (4)
HDD: 250GB
ODD interface: DVD SATA
Bays: (1) 5.25″ external, (1) 3.5″ external, (1) 3.5″ internal
RAID Controller: Yes
Front I/O: (2) USB 2.0, Audio I/O
Rear I/O: (6)USB 2.0, VGA, DP, RJ-45, Audio I/O
Dell Optiplex 980 DT i7 €250
Memory: 4 Gb DDR3
Intel Core i7-860 2,8 GHz
Intel HD Graphics 2000
3 years 1 month ago #279770 by tommylight
I will check tomorrow, i still have 2 of those.
Have good latency even with the RT kernel, never needed RTAI for these.
3 years 1 month ago #279776 by Marcodi
Hi, the MSI - P45 will definitely run this' I ran on similar gigabyte P45 for more than 10 years my linuxcnc in combination with Mesa cards. The other 4 I would personally not use , its older and you do want some reaction from the computer.
The following user(s) said Thank You: Kosmas
Time to create page: 0.293 seconds
