I would like to thank you Rodw and thank everyone for their help.
Your comments gave me some informations i was not expecting..
a. BesriWorld wrote above, "If the controller works well, it will not be affected by the latency of the computer."
It is correct finally but i didnt know why.
The following Research cleared to me the way this setup is working, in paragraph 2.
www.researchgate.net/publication/2716157...nd_Motion_Controller
In paragraph 2 says
"GT400-SV motion control card is embedded in the PC machine through the PCI slot.
Motion control card's CPU and PC's CPU as master-slave dual CPU control mode.
PC front end management for non real time tasks, such as man-machine interface, and other functions.
GT400-SV for real-time tasks, such as interpolation, servo control, I/O etc"
This confirms why Latency for this setup PC+Motion control card is not important.
b. You wrote that a PC with LinuxCNC has vastly more processing power than the Mach board. and its so true.
Why?
My motion controller has 120M working frequency and maximum step-pulse frequency at 1 Mhz
120M = 2.5Mhz. .
PC with J1900 proccesor has 2Ghz perSec.
or
650 MemoryOperationsPerSec on each of its 4 Threads.
2Ghz=800*2.5Mhz,
Even Ferrari vs Tortoise is 340Kmh/*0.5Kmh=680.
No other comment.
P.S.If anyone can suggest me a good motion control card for Linux CNC, i will set the machine in windows for now and will bye the card to change everything as soon as i can.
Sorry for my English and Thank you again.
Evangelos
