Intel N100
- perelep
28 Nov 2023 18:04 #286714
by perelep
Intel N100 was created by perelep
Hi!
Has anyone tested this CPU (Intel N100)? I want to buy Asus PRIME N100I-D D4-CSM or ASRock N100DC-ITX
Can you tell me if these are suitable boards?
- Thank you received: 7488
05 Dec 2023 12:17 #287264
Replied by tommylight on topic Intel N100
Not me, not yet.
Sorry.
Sorry.
- royka
- Thank you received: 135
05 Dec 2023 22:17 #287317
by royka
Replied by royka on topic Intel N100
I've got one, did a quick test a few months ago but did not get good results at that time. When I see time I'll test more. There are many BIOS options like different values for the turbo but didn't see the options I was looking for.
Perhaps it will perform better with the current kernel since it's a relatively new board.
- royka
06 Dec 2023 02:54 #287327
by royka
With the newer kernel/patch it works already much better, a few outliers but the only thing I've tried so far is isolcpus=3
- Mr. Mass
- Thank you received: 51
07 Dec 2023 06:14 #287415
by Mr. Mass
Replied by Mr. Mass on topic Intel N100
How exactly do you update the kernel?
- Thank you received: 426
07 Dec 2023 06:32 #287417
Replied by Cant do this anymore bye all on topic Intel N100
You can build your own kernel if you want.
Not the easiest task in the world.
You download the kernel source & the appropriate RT patch.
Extract the kernel source
Apply the patch
configure the kernel (this is where the real magic happens)
run make -j "$(nproc)" bindeb-pkg
then install the packages
The easier way:
Or if someone has built an updated kernel and provided deb packages you maybe able to install them.
Apply the patch
The easier way:
The following user(s) said Thank You: Mr. Mass
- royka
07 Dec 2023 14:10 #287444
by royka
This kernel has some AMD related stuff disabled, so only use with Intel.
mega.nz/folder/j2ZjUQ6A#wJAysWplOPS0-cyTy6OViQ
To compile your own is not that difficult, just download the source from GitHub, Download the matching patch from:
mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/
Apply the patch:
gzip -cd ../Downloads/patch-6.7-rc3-rt3.patch.gz | patch -p1
make menuconfig - be sure it's set to full realtime and exit/save
make -j "$(nproc)"
sudo make modules_install
sudo make install
Or like Cornholio said, make packages and install the headers, then the image:
Apply the patch:
make -j "$(nproc)"
sudo make install
The following user(s) said Thank You: rodw, Mr. Mass
- rebelx
- Thank you received: 11
28 Sep 2024 18:24 - 29 Sep 2024 06:24 #310991
by rebelx
Replied by rebelx on topic Intel N100
Intel N100 works great with Debian 13 (Trixie pre-release) and LinuxCNC 2.9.3-1+b2
I have achieved good results with a cheap and super small N100 mini PC, with 16GB of DDR5 memory, a 256GB NVMe drive, dual LAN and Wifi/BT. It is available on AliExpress and other channels as a T8 Plus and it is sold under different brand names. The price varies between 120.- and 200.- USD depending on the configuration. I attached some images below.
It came with Windows 11 Pro pre-installed and activated. I decided to go for a dual boot system, keeping Windows and installing Debian in a separate partition, so I could use Windows for my servo motor tuning software.
In order to try something new, which is usually more fun, I decided to install Debian Trixie (yes, pre-release Debian 13), via the text based installer, which went flawlessly. I chose Cinnamon for the GUI, which often gave me somewhat unstable lacencies under Debian 12, probably due to some graphics driver issues, and I was curious if Cinnamon would perform better under Trixie. After booting my new Debian 13 system, I opened Synaptic and installed linux-image-6.10.9-rt-amd64. Then I rebooted and confirmed that Debian was running with the RT kernel:
which showed: Linux <pc-name> 6.10.9-rt-amd64 #1 SMP PREEMPT_RT Debian 6.10.9-1 (2024-09-08) x86_64 GNU/Linux
Next I installed LinuxCNC version 2.9.3-1+b2 from the Trixie repository, including the optional dev package, via:
Nice to see that the latest stable release is automatically installed from the Debian Trixie repository
I did some latency tests without any BIOS changes or using isolcpus, and as to be expected the results were quite terrible with values for both the servo threat Max Jitter and base thread Max Jitter above 600000ns. (yes, six hundred thousand; it is not a typo). During the latency test I had 8 instances of glxgears running, internet connection via the build-in Wifi, Firefox had two tabs open with YouTube videos running and I was browsing the internet.
I then went into the BIOS settings and ONLY disabled Virtualization. After rebooting and doing another latency test, the results were much better, but still quite high. Before making any additional BIOS changes I decided to first play around with isolcpus to figure out which core(s) should be isolated from the general scheduler in order to get the best performance. I tested all possible combinations under the same test scenario as mentioned above, which took me several hours, and I found that isolcpus=1,2,3 resulted in the most optimal latency values. The Max Jitter values for both threads stayed below 20000ns, which is totally acceptable.
Next step was going back into the BIOS in order to disable things like C State and other power saving features, which is usually recommended to reduce latency, but strange enough disabling those only resulted in HIGHER latency instead of lower, so I stayed with only disabling virtualization and left the rest in their default settings. While I am typing this, the computer has been running for a few hours with the latency test and all those background programs running, and the Servo thread Max Jitter is 17646ns and the Base thread Max Jitter is 18711ns. Perhaps in the next few days I will take another look at the BIOS settings, trying to further reduce the latency, although I realize that is really not needed. All in all I am more than happy with this N100 mini PC. I will also test with some different desktop environments, especially lightweight environments like XFCE and LXQt. I may follow-up with another post about my findings.
As a PS: for those who want to use a Qt based GUI, like QtDragon, a Python file needs to be modified. Debian 13 comes with Python 3.12.6 installed. As from Python 3.12 locale.format is deprecated and needs to be replaced with locale.format_string in three places (lines 270, 277, 281) in the following file:
This fix is already implemented in the upcoming LinuxCNC 2.10 release, available on the LinuxCNC github page as a work in progress.
I hope this may be helpful for those looking for a modern cheap PC for LinuxCNC. N100 is definitely a suitable solution.
$ uname -awhich showed: Linux <pc-name> 6.10.9-rt-amd64 #1 SMP PREEMPT_RT Debian 6.10.9-1 (2024-09-08) x86_64 GNU/Linux
sudo apt install linuxcnc-uspace linuxcnc-uspace-devNice to see that the latest stable release is automatically installed from the Debian Trixie repository
$ sudo gedit /usr/lib/python3/dist-packages/qtvcp/widgets/origin_offsetview.pyThis fix is already implemented in the upcoming LinuxCNC 2.10 release, available on the LinuxCNC github page as a work in progress.
Last edit: 29 Sep 2024 06:24 by rebelx. Reason: Fixed some typos and added some more details.
- pippin88
29 Sep 2024 05:05 #311013
by pippin88
Replied by pippin88 on topic Intel N100
isolcpus does not disable cores
isolcpus isolates designated cores from the general scheduler
So routine tasks won't be assigned to those cores. E.g. web browser running in the background won't take CPU time on isolated cores
- rebelx
29 Sep 2024 05:19 - 29 Sep 2024 06:54 #311014
by rebelx
Yes, that is what I actually meant, but you found a more correct way to say it
I updated the text. Thank you for correcting me!
Isolating cores from the general scheduler and how that impacts latency always feels a bit like black magic to me, and results can vary quite a lot between different processor architectures. I remember using a J1900 board, where isolplus=1,2 gave the best results, which I guess may be related to how the cores are internally arranged on the die in two pairs, cores 0 and 1 being on one half of the die and sharing resources, and cores 2 and 3 sharing the other half. I guess limiting the general scheduler to only use one core per pair has an impact on interrupts and latency. I am not sure how the N100 is internally organized and how that may be impacting latency.
Do you know if there are any articles that explain how exactly LinuxCNC tasks are assigned to isolated cores? I would be interested in learning more about it. The main reason being that I am looking at some Arm based solutions that combine both application processors (e.g. Cortex-A53/55 capable of running Linux) and microcontrollers (e.g. CortexM7/33) in one chip. Some even have a dedicated DSP, which can be an efficient way to handle PIDs and so forth. Although my primary interest in this area is something else than CNC machine control, I think it would be very interesting to see if we could port LinuxCNC to such a platform, where the general Linux part of LinuxCNC can run on a Cortex-A, and where the real-time tasks can be performed on a Cortex-M, independently from the application processor. This separation could free us from Intel and AMD and how their platforms are more geared towards gamers than industrial low latency applications.
Last edit: 29 Sep 2024 06:54 by rebelx.
Time to create page: 0.467 seconds
