frozen screen with linuxcnc 2.9.1 y kernel RTAI 5.4.258
20 Dec 2023 16:18 - 21 Dec 2023 16:41 #288710 by Ismacr63
Hello. I come from this thread:
forum.linuxcnc.org/9-installing-linuxcnc...an-6?start=20#288708
The fact is that I thought I had a problem with the installation of linuxcnc 2.9.1 and kernel rtai 5.4.258.
The installation is fine since I have put the SSD disk on another motherboard and it works correctly.
The problem is that when I start the latency test or linuxcnc itself, the screen freezes and I have to restart the PC. I have played with all the bios options and the problem continues. I have also tried an Nvidia and another Radeon graphics card and the problem still exists.
with linuxcnc Preempt-RT kernel it works perfectly, but I need rtai because I use a parallel port.
The motherboard is gigabyte h110m ds2 with 16gb ram i3 6100 processor
Last edit: 21 Dec 2023 16:41 by Ismacr63.
20 Dec 2023 16:43 #288712 by tommylight
Should have posted on the link i posted there, not start a new topic.
As it is a RTAI kernel issue with only some specific hardware, it is very difficult to help with it or to point in any direction.
This is not a LinuxCNC issue (LinuxCNC does not use RTAI kernel anymore, it is provided by some members here to help with older hardware as there are still plenty PC's with parallel port in use), nor is this a Debian issue so searching on Debian forums might help, but chances are low. Then again, might be worth a try.
The following user(s) said Thank You: Ismacr63
20 Dec 2023 16:52 #288714 by Ismacr63
sorry, you're right. I delete it and write in the thread that he told me.
thank you!
23 Dec 2023 09:34 #288920 by Ismacr63
I have managed to get the latency test to run, but when I try to start linuxcnc an error appears.
Warning: Spoiler!
23 Dec 2023 09:51 - 23 Dec 2023 09:54 #288922 by tommylight
Segmentation fault, usually due to failing memory modules or memory controller (not always).
Do you have other memory to test with?
Or, if there are more than one module, remove all and insert one at a time and test.
Edit:
Sometimes, failing power supply can also cause seg faults.
Last edit: 23 Dec 2023 09:54 by tommylight. Reason: more info
23 Dec 2023 13:09 #288936 by Ismacr63
Edit:
The memories are new, literally a month old. There are 2 modules of 8GB DDR4 each. Even so, I have checked them and they are fine, I have also tried with a single ram module.
To make the latency test work I have flashed an older bios, I have been updating the bios until I reach one that starts to freeze the system when starting anything related to linuxcnc. I have to say that it only happens with the rtai kernel. I get that error message, although sometimes Linux starts without any error.
28 Nov 2025 16:03 #339404 by andypugh
Segfaults are typically problems with the linuxCNC software writing out-of-bounds.
Are you running any custom HAL modules?
Which HAL components are in-use?
Sorry, but RTAI support has been a bit lax lately, though I am still committed to it at least in 2.9.
Time to create page: 1.276 seconds
