- Thank you received: 426
I have been working (playing) with Rpi5 and Bookworm with preempt_rt. I have preempt_rt running on RPi4 and RPi5 (separate compiles). The RPi4 uses bcm2711_defconfig while the RPi5 uses bcm2712_defconfig. I have kernel version 6.6.20-rt25-v8 (-4k+ on the RPi4) and (-16k+ on the RPI5).
In the last couple of weeks they have added support for spi CS for additional cs pins. I am currently running the kernel on Raspian Bookworm but I have previously used the same sources to compile kernels on straight debian. If anyone is interested, I will put my sources up on my GitHub.
For awhile I was having difficulty getting the kernels to load but now I seem to have the process down. I will try shortly loading the kernel on the linuxcnc image for RPi5 to verify that the same kernel will run on both debian and raspian bookworm.
