- Thank you received: 5334
Thanks mecanix! That seems to have made the difference. I can now run Linuxcnc and get to my network and the internet all at the same time.No idea if this will solve your issue however if you plan on prioritizing the wifi over nic, then the metric needs to be set for both option. And so you might want to set that first.
### The lowest the metric n is, the highest priority it will be given.[/code]Code:$ sudo nmcli connection down "your_wifi_conn_name" $ sudo nmcli connection modify "your_wifi_conn_name" ipv4.route-metric 100 $ sudo nmcli connection up "your_wifi_conn_name" $ sudo nmcli connection down "your_wired_conn_name" $ sudo nmcli connection modify "your_wired_conn_name" ipv4.route-metric 200 $ sudo nmcli connection up "your_wired_conn_name" ### To find both "your_wifi_conn_name" and "your_wired_conn_name", use: [code]$ nmcli connection show
I set up the nic based on tommylight's sticky on "Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards". The nic is set with an address of 10.10.10.11 and the gateway is set to 10.10.10.1.The problem is that the 10.10.10.1 address is a default route
That's an error in setting up the 10.10.10.1 interface
