ESP32 HAL2UDP setup for linux CNC noob.
1 year 2 months ago #333948 by tommylight
Use the serial monitor feature to see if the ESP is connected and working.
Use ping to make sure network is set up properly, ping the W5500 on the address you set in PlatformIO/Code
1 year 2 months ago #333971 by lj
I think I found the problem. I am using a straight through instead of the cross over Ethernet cable I should be using
thanks for the help
Time to create page: 0.105 seconds
