Fresh install freezes when running glxgears
03 Apr 2024 19:13 - 03 Apr 2024 19:15 #297523 by reneas
As the topic says, after a fresh install of LinuxCNC 2.9.2 the system crashes when I run glxgears...
The screen freezes completely and I can't input anything. It still works to move the mouse but I can't click anything. Keyboard shortcuts aren't working as well.
What can I do?
My graphics card is a Nvidia 6600 GT and I did sudo apt update & upgrade after installing.
Last edit: 03 Apr 2024 19:15 by reneas. Reason: Clarification
03 Apr 2024 19:40 #297532 by tommylight
Replied by tommylight on topic Fresh install freezes when running glxgears
Did you install drivers for graphic card?
Do not, they cause trouble with real time kernels.
Nvidia always caused issues with latency, but locking the screen, i never had that.
Does the motherboard have integrated graphic? If yes, yank Nvidia out and give it a try.
04 Apr 2024 22:37 #297605 by reneas
Replied by reneas on topic Fresh install freezes when running glxgears
Hmmm might have installed some... How can I remove them? Or should I run a new fresh install? The weird thing is, that glxgears worked on that PC but now it doesn't anymore. I can't remember if I used the on board graphics or internal graphics card for that...
I'll hopefully look into it tomorrow and get back to this thread!
05 Apr 2024 13:22 #297644 by reneas
okay so when taking out the graphics card running glxgears works perfectly fine. with the graphics card inserted it still doesn't work at all.
I also tried to use the
vblank_mode=0
option but that also didn't help. So is the only possibility to get this to work to just not use a graphics card? i thought when using one the latency of the pc will drop because the motherboard is not that busy or is that wrong?
Time to create page: 0.183 seconds
