Robot 5-DOF on Raspberry Pi
- Project_Hopeless
- Thank you received: 10
16 Apr 2024 01:57 #298325
by Project_Hopeless
Robot 5-DOF on Raspberry Pi was created by Project_Hopeless
I have a 3D printed robot, 5-DOF (Melfa based) I'm planning on running off a Rasberry Pi 4, running Axis or similar GUI, visMach, over Ethernet to a Mesa card.
Am I asking too much of a Pi? What memory size would I need, knowing more is better but not always necessary.
- Thank you received: 426
16 Apr 2024 05:54 - 16 Apr 2024 05:58 #298340
Replied by Cant do this anymore bye all on topic Robot 5-DOF on Raspberry Pi
If you have a Rpi4 give it a go.
If you have the choice between a 5 and a 4 go for the 5.
If you do go for the 5, I'd suggest against using the Rpi5 image, as much as Rodw has put into it there are some nice things missing, installing Linuxcnc & a RT kernel isn't that hard on a Raspios image.Actually building Linuxcnc on the RPi5 is pretty quick, if you need to go that way.
If you haven't got a Raspberry Pi on hand and space isn't a issue you'll get more bang for buck with SFF system.
Last edit: 16 Apr 2024 05:58 by Cant do this anymore bye all.
Time to create page: 0.072 seconds
